GaryP wrote:
Sean Trost wrote in message r.com... Hi all ! What would be a problem if any with rebuilding a lycoming case with a deck height out of spec. snip Deck height is the distance from the crankshaft centerline to the cylinder barrel mounting surface. Machine shops that overhaul cases have a fixture for taking this measurement. Once a case has been overhauled to the point where it is below critical deck height several undesirable things happen. As you mentioned, piston TDC depth in the cylinder might be so great that it hits the head or one of the valves. Hydraulic lifter dynamic adjustment range could be exceeded and the valve clearance not properly maintained under all thermal conditions by the lifter. But there is also accessory gear problems too. When the mating surfaces of a case are planed flat the crank and cam bearing holes are made oval. These then need to be line bored to make them perfectly round again. This effectively moves the crank and cam centerlines outward in each case half. If there are gear driven accessories on the back in fixed locations (e.g. mags, etc) the gear teeth on the crank and/or cam may now be meshed to deeply with those on the accessories. All of these issues factor in the the determination of critical deck height and render a case beyond its usefull life. Any reputable case overhauler like Divco or Ajax should be able to tell you what the critical deck dimension is for your engine case. Now if you were rebuilding a VW engine, which doesn't have an accessory case and uses solid lifters, you would simply use cylinder barrel shims to account for deck height. But I digress... Gary Concise and coherent explanation. In fact, my only objection (at all!) is in reference to the VW engine in the last paragraph. There are several accessory cases available for the VW. Most are single ignition setups, but I've seen at least one that supported dual mags. Thanks, Gary. Ya done good. Respectfully, Richard Lamb |
Richard Lamb wrote in message ...
Concise and coherent explanation. In fact, my only objection (at all!) is in reference to the VW engine in the last paragraph. There are several accessory cases available for the VW. Most are single ignition setups, but I've seen at least one that supported dual mags. Thanks, Gary. Ya done good. Respectfully, Richard Lamb Doh! I knew I shouldn't have digressed g. I've never seen an accessory case for a VW beyond the Great Plains variety which capped off the flywheel flange to accomdate a webbed ring gear for a starter and crank driven mag. Nothing affected by deck height using this arrangement. But if someone out there makes an accessory case for a VW with a gear driven dual mag set up, then that is a different story and I stand corrected. Regards, Gary |
Cylinder Wrenches for 0-320A Narrow Deck | DAVE | Home Built | 1 | December 31st 03 01:45 PM |
Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 07:42 AM |
