Using other freqs to communicate between planes or ground?
Old October 26th 04, 10:17 PM
gerrcoin
Just to add that transmissions from an aircraft can travel much
further than ground transmissions. So just because you never hear
anything on a particular freq does not mean that you will not cause
interference on it. Airport receivers have quite good reception and
certain atmospheric conditions can boost the propagation of radio
signals by a surprising amount. Stick to assigned freqs or, as peter
has mentioned, 123.45 is considered to be a common chat channel.
Old October 26th 04, 10:26 PM
Peter Duniho
"gerrcoin" wrote in message
[...] Stick to assigned freqs or, as peter has mentioned, 123.45 is
However, as I also mentioned, it's not an approved channel. It's reserved
for ground test stations.
If you're going to chat on the radio in the air to other stations in the
air, you should do so on 122.75, which is the frequency specifically set
aside for air-to-air communication.
I would also use 122.75 for student-to-instructor communications, when the
instructor is on the ground with a hand-held for example, even though that's
patently illegal (it's not an air-to-ground frequency, and the handheld is
not a legal station for the purpose of transmitting).
Pete
Old October 26th 04, 11:27 PM
Dave S
What makes a handheld illegal? Public safety folks get licensed for and
use handhelds all the time. Its licensed as either a mobile or a
portable (its been a LONG time since I've been around em)..
Dave
Pete
Old October 27th 04, 12:35 AM
Peter Duniho
"Dave S" wrote in message
ink.net...
I should have been more clear. I was talking of the typical use, in which
no station or operator's license exists to legalize the use.
You're right that if a CFI goes to the trouble to get the appropriate
license, they may use a handheld radio as a licensed station.
Old October 26th 04, 11:47 PM
Jim Weir
"Peter Duniho"
-However, as I also mentioned, it's not an approved channel. It's reserved
-for ground test stations.
Nope. Subpart J is entitled FLIGHT Test stations.
-If you're going to chat on the radio in the air to other stations in the
-air, you should do so on 122.75, which is the frequency specifically set
-aside for air-to-air communication.
-I would also use 122.75 for student-to-instructor communications, when the
-instructor is on the ground with a hand-held for example, even though that's
-patently illegal (it's not an air-to-ground frequency, and the handheld is
-not a legal station for the purpose of transmitting).
A SINGLE instructor with a SINGLE student has been found to qualify for Subpart
K Flight School frequencies 123.3 and 123.5. The handheld is a perfectly legal
station for use in this service, but as I've pointed out several times, the
individual flight instructor (or their flight school) must apply for the license
and pay the fee.
The point of all this rambling is that there is a frequency available for almost
any use and almost any condition, but unless the stations at both end of the
communications link are authorized AND LICENSED on these frequencies, then the
communications FROM BOTH ENDS are illegal.
http://www.rst-engr.com
Old October 26th 04, 11:41 PM
Jim Weir
The hell it is. See previous dissertation.
gerrcoin
-has mentioned, 123.45 is considered to be a common chat channel.
Old October 26th 04, 11:51 PM
Steven P. McNicoll
"Jim Weir" wrote in message
Actually, 123.45 IS considered by many to be a common chat channel. It is
NOT a common chat channel, of course, but that doesn't change the fact that
many believe it is.
Old October 27th 04, 12:23 AM
Bob Gardner
In the Northwest, 123.45 is assigned to the Boeing Company Flight Test
Department. This is a long and complicated URL, but it is a somewhat
up-to-date list of companies assigned to use 123.45.
http://gullfoss2.fcc.gov/cgi-bin/ws....00123.45000000
We use the aviation radio frequencies as a privilege, not a right. Don't
make up your own rules.
Bob Gardner
Just to add that transmissions from an aircraft can travel much further
than ground transmissions. So just because you never hear anything on a
particular freq does not mean that you will not cause interference on it.
Airport receivers have quite good reception and certain atmospheric
conditions can boost the propagation of radio signals by a surprising
amount. Stick to assigned freqs or, as peter has mentioned, 123.45 is
Old October 27th 04, 04:11 AM
Jens Krueger
Which is just a common misconception. 123,45 is no more a designated
air-to-air frequency then anything else. The FCC has 122,75 and 122,85
authorized for air-air and air-to-ground on private airports. 123,02 is
for helicopter air-to-air.
123,45 just "stuck" with a lot of pilots because it's easy to remember.
Check 4-1-11 b) 2) in the AIM.
Cheers,
Jens
I don't accept any emails right now. Usenet replys only.
FS: 1989 "War Planes" (Of The World) Cards with Box J.R. Sinclair Aviation Marketplace 0 December 30th 04 11:16 AM
Red Alert: Terrorist build kamikaze planes for attacks Hank Higgens Home Built 5 April 16th 04 02:10 PM
FS: 1989 "War Planes" (Of The World) Cards with Box J.R. Sinclair Aviation Marketplace 0 April 15th 04 06:17 AM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 12:17 AM
FS: 1989 "War Planes" (Of The World) Cards with Box Jim Sinclair Aviation Marketplace 0 August 23rd 03 04:43 AM
Copyright Đ2004-2025 AviationBanter.
