Using other freqs to communicate between planes or ground?
Old October 26th 04, 11:09 PM
Jim Weir
"Gary G"
-I've wondered if it is legal to utilize an "unused" frequency to communicate
between planes or
-to someone on the ground for non-critical communication?
Absolutely not, unless the "unused" frequency is assigned by license to either
you or the ground station. There is only one air to air frequency for airPLANES
(122.75) and another one for rotorwing aircraft (123.025). (Ref 47CFR87 sub F)
-Is that legal?
Again, illegal as hell unless one of you has applied for and been granted the
FCC (not FAA) license for the frequency for the purpose intended in 14CFR87.
http://www.rst-engr.com
Old October 27th 04, 03:27 AM
StellaStar
Jim, got a link for how to apply for the permit required?
I learned that (perhaps it's a state law) law-enforcement types don't want you
to use a portable scanner-type radio tunable to cop frequencies when you're
mobile. It's understandable, given the tendency of Bad Guys to use such a
situation to evade enforcement. But a licensed ham radio operator is exempt
from that. I carry a printout of that regulation in my glove compartment since
I carry a portable scanner...even though it's programmed only with aviation
frequencies.
If it's not ferociously expensive I could see getting the required license in
case I can ever afford a mobile radio that transmits on the av freqs, too.
FS: 1989 "War Planes" (Of The World) Cards with Box J.R. Sinclair Aviation Marketplace 0 December 30th 04 11:16 AM
Red Alert: Terrorist build kamikaze planes for attacks Hank Higgens Home Built 5 April 16th 04 02:10 PM
FS: 1989 "War Planes" (Of The World) Cards with Box J.R. Sinclair Aviation Marketplace 0 April 15th 04 06:17 AM
Conspiracy Theorists (amusing) Grantland Military Aviation 1 October 2nd 03 12:17 AM
FS: 1989 "War Planes" (Of The World) Cards with Box Jim Sinclair Aviation Marketplace 0 August 23rd 03 04:43 AM
Copyright Đ2004-2025 AviationBanter.
