Richard Lamb wrote in message ...
Concise and coherent explanation. In fact, my only objection (at all!) is in reference to the VW engine in the last paragraph. There are several accessory cases available for the VW. Most are single ignition setups, but I've seen at least one that supported dual mags. Thanks, Gary. Ya done good. Respectfully, Richard Lamb Doh! I knew I shouldn't have digressed g. I've never seen an accessory case for a VW beyond the Great Plains variety which capped off the flywheel flange to accomdate a webbed ring gear for a starter and crank driven mag. Nothing affected by deck height using this arrangement. But if someone out there makes an accessory case for a VW with a gear driven dual mag set up, then that is a different story and I stand corrected. Regards, Gary |
Cylinder Wrenches for 0-320A Narrow Deck | DAVE | Home Built | 1 | December 31st 03 01:45 PM |
Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 07:42 AM |
