Sylvia Else wrote:
There have been incidents where airliners have been stressed well beyound their design limits to recover from extreme upsets, and the passengers and crew have survived to fly another day, "design limits" is the real keyword here. And it applies to bridges as well as buildings. The empire state building was built with tons of extra strength into it because at the time, the knowledge of structural aspects of materials was not very good. So you end up with a big fat heavy building that is very strong. More recent buildings are built with much better knowledge of materials and thus are built with more exact strength, much lighter materials and much thinner structure. Similarly, modern aircraft are built with much better knowledge of material properties as well as aerodynamics. So the difference between the stated limits and the actual physical limits are far less than planes built in the 1960s. So breaking the "limits" today may in fact be far more dangerous than breaking the much less well known limits of the 1960s. The A300 crash is a perfect example of why FBW is a good thing. had there been FBW on that system, the pilot could have commanded the rudder to the max, and the computer would have ensured that it only moved as far as was safe, allowing pilot to concentrate on flying the aircraft instead of guessing what the limits would be in that flight regime. From what I have been told, the 320 330 and 340s do not have computer authority on the rudder, one reason being that the rudder is so rarely used in flight. (AA being the odd airline out). However, I suspect that the 380 and 350 will have computer authority on the rudder. |
On Wed, 27 Oct 2004 at 01:02:58 in message
, nobody wrote: The A300 crash is a perfect example of why FBW is a good thing. had there been FBW on that system, the pilot could have commanded the rudder to the max, and the computer would have ensured that it only moved as far as was safe, allowing pilot to concentrate on flying the aircraft instead of guessing what the limits would be in that flight regime. Surely maximum deflection is not the issue? It is reversing from the maximum one way to the other and perhaps back again that is the issue. On the other hand maybe FBW may not have touched the rudder? Many aircraft have had the maximum deflection automatically reduced after the speed passes a certain point. Did the A300 have this? I think it did but I am not sure of my recollection. -- David CL Francis |
![]() "nobody" wrote in message ... Sylvia Else wrote: There have been incidents where airliners have been stressed well beyound their design limits to recover from extreme upsets, and the passengers and crew have survived to fly another day, "design limits" is the real keyword here. And it applies to bridges as well as buildings. The empire state building was built with tons of extra strength into it because at the time, the knowledge of structural aspects of materials was not very good. So you end up with a big fat heavy building that is very strong. More recent buildings are built with much better knowledge of materials and thus are built with more exact strength, much lighter materials and much thinner structure. Similarly, modern aircraft are built with much better knowledge of material properties as well as aerodynamics. So the difference between the stated limits and the actual physical limits are far less than planes built in the 1960s. So breaking the "limits" today may in fact be far more dangerous than breaking the much less well known limits of the 1960s. Johnson's flight demonstration of a early 707 being a prime example. Modern day commercial A/C would never probably not survive, but if it did to the scrap heap it would go. Ralph Nesbitt Professional FD/CFR/ARFF Type |
Military: Pilot confusion led to F-16 crash that killed one pilot | Otis Willie | Military Aviation | 0 | September 1st 04 12:30 AM |
P-51C crash kills pilot | Paul Hirose | Military Aviation | 0 | June 30th 04 05:37 AM |
Fatal plane crash kills pilot in Ukiah CA | Randy Wentzel | Piloting | 1 | April 5th 04 05:23 PM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
