Cub Driver wrote in message . ..
Okay, I gave myself the early birthday present. I can't believe how sensitive the 296 is. I stroll down to the dock and it tells me that I am tracking 178 degrees at 1 knot; I turn around and walk back, and THE MAP FLIPS! and I am tracking 348 degrees (whatever). I even got it to show a bank on the panel display when I walked briskly along and tilted the GPS. Anyhow, my question: I set it to show Zulu time and magnetic compass readings. Then I wondered: is this the right thing to do? Is this the right thing to do? Are there any other basic settings I should set now that will improve my life to come? I just bought one this summer. I found it very non-intuitive to use. After flying behind it for about 100 hours I think I'll dump it. I'm most annoyed by the fact that it doesn't show airways on the map. The screen is also smaller than my SkyMap IIIC and the terrain on the 296 always seems to be wrong (its usually off by at least 1000 feet). I also don't like the fact that the only way to get a course line is to put it in marine mode. I like being able to fly to an airport simply by turning until the course line falls on the airport. The design of the screen is very odd to me too. They put most of the room to the side of the plane. They should have designed the screen to be taller and perhaps more narrow. I'm more concerned with what is ahead of me than what is to the side. I still have my SkyMapIIIc with the terrain database so I'll probably swap back to that. -Robert |
huh. on my 196, its been intuitive after playing around with it. It also
shows a course line, so I can't see why the 296 wouldn't have it either. John |
![]() "Robert M. Gary" wrote in message om... Cub Driver wrote in message . .. Okay, I gave myself the early birthday present. I can't believe how sensitive the 296 is. I stroll down to the dock and it tells me that I am tracking 178 degrees at 1 knot; I turn around and walk back, and THE MAP FLIPS! and I am tracking 348 degrees (whatever). I even got it to show a bank on the panel display when I walked briskly along and tilted the GPS. Anyhow, my question: I set it to show Zulu time and magnetic compass readings. Then I wondered: is this the right thing to do? Is this the right thing to do? Are there any other basic settings I should set now that will improve my life to come? I just bought one this summer. I found it very non-intuitive to use. After flying behind it for about 100 hours I think I'll dump it. I'm most annoyed by the fact that it doesn't show airways on the map. The screen is also smaller than my SkyMap IIIC and the terrain on the 296 always seems to be wrong (its usually off by at least 1000 feet). I also don't like the fact that the only way to get a course line is to put it in marine mode. I like being able to fly to an airport simply by turning until the course line falls on the airport. The design of the screen is very odd to me too. They put most of the room to the side of the plane. They should have designed the screen to be taller and perhaps more narrow. I'm more concerned with what is ahead of me than what is to the side. I still have my SkyMapIIIc with the terrain database so I'll probably swap back to that. -Robert How much do you want for it? |
"Blueskies" wrote in message ...
How much do you want for it? I think Sporty's will still take it back. If not, I'll put it on eBay. |
After flying behind it for about 100 hours I think I'll dump it. I'm most annoyed by the fact that it doesn't show airways on the map. Have look at the AvMap, it is big and it has a lot of features, even approaches, but VFR only. |
All handheld are VFR only. The Garmin 296 does not have a higher learning
curve than any other. Karl "Hankal" wrote in message ... I just bought one this summer. I found it very non-intuitive to use. After flying behind it for about 100 hours I think I'll dump it. I'm most annoyed by the fact that it doesn't show airways on the map. Have look at the AvMap, it is big and it has a lot of features, even approaches, but VFR only. |
Amateur Review of the Garmin GPSMAP 296 GPS | Rhett | Piloting | 10 | March 23rd 05 01:16 AM |
Pirep: Garmin GPSMAP 296 versus 295. (very long) | Jon Woellhaf | Piloting | 12 | September 4th 04 11:55 PM |
garmin 296 | Robert M. Gary | Piloting | 12 | June 17th 04 10:14 PM |
Garmin DME arc weidnress | Dave Touretzky | Instrument Flight Rules | 5 | October 2nd 03 02:04 AM |
Garmin 90 Database Updates Discontinued | Val Christian | Piloting | 14 | August 20th 03 09:32 PM |
