Co-pilot error caused AA 587 crash
Old October 29th 04, 10:09 AM
Stefan
Pooh Bear wrote:
Hence they thought they were flying at 100ft when it was actually 30 ft.
They were indeed unaware
of the trees due to the poor briefing material.
Being a hard core "look out the window and fly by horizon and feel"
pilot, I have some difficulties to understand this. I'm aware that you
can't fly an airliner by merely looking out the window, but still....
Besides, the briefing material itself wasn't poor. The VAC clearly shows
the forest:
http://www.sia.aviation-civile.gouv....D%202.LFGB.pdf
The "problem" was that the pilot expected to do his show-off over the
runway 20, which has no trees at the far end. When he recognized that
the public was lined up along the glider strip 16, he changed his plans
accordingly and overlooked that this runway was significantly shorter
(i.e. 765 instead of 1120 ft) and there was forest at both ends of the
strip. Which, as I said, I don't understand.
Stefan
Old October 29th 04, 12:17 PM
Stefan
Ooops, this should be meters, of course!
Stefan
Old October 29th 04, 07:53 PM
Pooh Bear
I hear what you're saying here. It was claimed by the flight crew that since they were used to
flying in and out of large airports, the visual references of a small airfield gave them a false
impression.
the forest:
I hear that they received only a faxed ( hence black and white ) copy of the relevant map.
strip.
That too. There is literally one factor after another that contributed to this accident.
Sorry, which bit don't you understand ? Overlooking the shorter runway length ?
Graham
Old October 29th 04, 09:48 PM
Stefan
impression.
I must admit that this makes some sense.
No, the forest, of course. I think a pilot should be able to recognize a
forest when seeing it, even if it should happen not to be on the VAC...
Can't remember why I even mentioned runway length.
Stefan
Old October 30th 04, 04:10 AM
Pooh Bear
impression.
Pre-occupation with the current task might be the reason ? Think about the Tristar that descended into
the Everglades 'cos the flight crew were trying to see if they had a broken indicator lamp for
example.
Graham
Old October 30th 04, 11:09 PM
Bertie the Bunyip
Pooh Bear wrote in message ...
impression.
example.
what's it to you, wannabe netkkoping ****?
Bertie
Military: Pilot confusion led to F-16 crash that killed one pilot Otis Willie Military Aviation 0 September 1st 04 12:30 AM
P-51C crash kills pilot Paul Hirose Military Aviation 0 June 30th 04 05:37 AM
Fatal plane crash kills pilot in Ukiah CA Randy Wentzel Piloting 1 April 5th 04 05:23 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
