When people talk about being "on the step" they are talking about their
being a cruise speed above that which can be obtained by accelerating in level flight. It is a bunch of BS. You are correct that there are two speeds achievable at any given power setting, one above L/D max and one under. There are not TWO speeds above L/D max. In the case of any airplane, if you have power to climb, you have power to accelerate. There is no case where you can climb to an altitude and not accelerate to whatever cruise speed is availible (and there is only one). Mike MU-2 "Corky Scott" wrote in message ... On Sun, 31 Oct 2004 14:05:51 -0800, "Peter Duniho" wrote: Bottom line: if there were really something to it, it would be wide-spread industry and military practice. And yet, all those folks continue to climb to their altitude, accelerate to cruise speed and then throttle back to maintain that speed. Perhaps there is something to it then, check out this blurb from a 747 discussion group, the subject for this discussion was started by someone asking about flying on the step: ***Begin quote*** As for flying 'on the step', I believe Jetguy's on the money. For a given power setting there will be two speeds available (ie: the two points on the curve where power available = power required). Being 'on the step' is when you're flying at the higher of the two speeds. On a video today I saw a demonstration of how to get 'off the step'. The scenario was a CX B747-400 simulator with RB211-524H engines. The aircraft was placed at 40,000' and at a weight which gave a margin of approximately 30-40kts between the stall and high speed buffet. At a speed ~ 10kts below the high speed buffet the thrust was reduced, decellerating in level flight until the onset of the pre-stall buffet. By this time the aircraft had gone past the lower speed at which level flight could have been maintained with the initial power setting (ie: the 'off the step speed'), and was so far up the back side of the power required curve that full power was needed to maintain level flight, and stop the IAS from reducing further. The only solution was to descend, trading a bit of that potential energy to accelerate the aircraft onto the right side of the drag curve, and then recapture the initial altitude (if you wanted to test your luck in coffin corner). A very interesting demo which certainly highlights one of the major differences between putting around in a Cessna and high altitude jet transports. ***end quote*** This would appear to be specific to swept wing airliners only. My father, who flew PB4Y-1's and -2's told me about the climb above and dive down to cruising altitude technique which he used for his long range patrol. The PB4Y-1, called the "Privateer" by the Navy, was the navalized version of the B-24. Loaded for patrol, it would have been substantially overgross. The B-24 also had a wing called the Davis Wing, which had a very narrow cord (high aspect ratio) and it's likely that it had a narrowly defined best cruise angle of attack. I think it's possible that if you did not accelerate to the proper airspeed, you could spend a long time wallowing along behind the power curve before enough fuel burned off to allow the airplane to nose down to the proper angle of attack. I agree though that finding that proper cruise attitude and speed could be achieved by the diving down method as well as leaving climb power on and throttling back once the proper speed has been reached, or slightly exceeded. The point is to exceed it slightly before throttling back, I doubt the airplane cared which way you managed that. Corky Scott |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 07:33 PM |
Announcing THE book on airshow flying! | Dudley Henriques | Military Aviation | 2 | January 7th 04 03:41 PM |
U.S. NAVY TO TEST FLYING SAUCER | Larry Dighera | Piloting | 0 | December 22nd 03 07:36 PM |
