#28
A 1956 B-36J flight manual that I have recommends slightly
overshooting the desired cruise altitude: "As the planned level-off altitude is attained, the aircraft may be climbed 200 to 500 feet above cruising altitude prior to reducing power unless instrument flight rules dictate leveling off at the exact altitude. This small amount of altitude will allow a cushion for the pilot to trim the aircraft while the engineer is stabilizing reciprocating power. Regardless of level-off technique, the engineer has sufficient power available from the reciprocating engines, at less cost in fuel consumption to complete this maneuver." The overshoot on level-off could be airspeed instead of altitude: "Many engineers have found it desirable to hold the climb power after leveling off so that the airplane accelerates rapidly to a figure well above the final anticipated value. Some cooling benefits are derived during this period with increasing air speeds. Then power is reduced on all engines to a point which is slightly above the final amount so that while the manual leaning procedure is followed, the necessary power reductions on individual engines do not result in allowing the airplane to decelerate below the recommended air speed." But there's no indication in the B-36 flight manual that approaching cruise "from above" produced a higher stabilized speed. It simply made the transition from climb to cruise easier. -- Paul Hirose To reply by email delete INVALID from address. |
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flying is Life - The Rest is Just Details | Michael | Piloting | 55 | February 7th 04 03:17 PM |
Announcing THE book on airshow flying | Dudley Henriques | Piloting | 11 | January 9th 04 07:33 PM |
Announcing THE book on airshow flying! | Dudley Henriques | Military Aviation | 2 | January 7th 04 03:41 PM |
U.S. NAVY TO TEST FLYING SAUCER | Larry Dighera | Piloting | 0 | December 22nd 03 07:36 PM |
