It was the only way they could get a signal in both the civilian and military
air bands. If you want to be able to use the military homing gear that is restricted to military frequencies, you had to have part of your signal in the military band. It is a crystal BITCH making an antenna that is as good a radiator at the fundamental as the second harmonic. Jim Chuck Forsberg WA7KGX shared these priceless pearls of wisdom: -Is the second harmonic of the 121.5 ELT signal used by satellites -or a significant number of homing receivers? Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Effect of Light Sport on General Aviation | Gilan | Home Built | 17 | September 24th 03 06:11 AM |
