From the ground up ... question about riveting
Old July 18th 04, 05:37 PM
Marco Rispoli
Default From the ground up ... question about riveting
I was watching "From the Ground Up" on Discovery Wings, specifically I paid
attention to the episode where the rivet the skin on one of the wings of the
aircraft.
in order to rivet the skin to the aircraft they use solid rivets, a rivet
gun and a "bucking bar" (did I get that right?).
The rivet is pounded by the gun on the outside while on the inside the
bucking bar bounces against the other end of the rivet flattening it against
the inside hole.
Cool.
It took 3 people to do that: 1 to handle the gun, 1 to keep the skin "bent
up" while the other was keeping the bucking bar against the rivet.
You could reduce that to 2 people if you have the person handling the
bucking bar also bending the skin up.
My question is this (to you more experienced metal-airplane-builder folks):
is it possible to do this "solo"? From the looks of it the answer is a big
resounding NO. I can't imagine anyone other than a contortionist with 4 arms
handling the gun, the bucking bar and keeping the wing skin out of the way
and doing a good job at it at the same time.
Right?
Marco Rispoli - NJ, USA / PP-ASEL
My on-line aviation community - http://www.thepilotlounge.com
Old July 18th 04, 08:22 PM
Orval Fairbairn
aircraft.
the inside hole.
Cool.
Right?
Wrong! It IS quite possible (and easy) for one person to do this
operation.
We use Cleco fasteners to hold the skins in place for the riveting --
usually we drill and cleco 3/32" rivets and then, if we want to go with
larger rivets, drill out to the desired size, holding the skins in place
with clecos.
On homebuilts, we can usually reach both sides of the skin, one hand
operating the rivet gun and the other hand holding the bucking bar. If
we had to use larger rivets than #3 or #4, I suppose that the job would
be more difficult.
Incidentally, we do NOT flatten the shop head, but we buck it to a
desired length & diameter and have go/no-go guages for the less
experienced riveters.
The real secret here is to take it easy and not try to rush the job or
to work while tired -- those actions usually result in mistakes.
Old July 18th 04, 11:46 PM
Kyle Boatright
You can rivet 90% of the rivets on an RV solo. The wing skins and some of
the fuselage skins are the primary exceptions. You need two people for
those. It amounts to about 1% or less (honest!) of the total build time.
KB
"Marco Rispoli" wrote in message
et...
paid
aircraft.
against
the inside hole.
Cool.
folks):
arms
Right?
Old July 18th 04, 11:57 PM
Rich S.
"Kyle Boatright" wrote in message
And. . . pick someone who won't drop the bucking bar inside the wing!
Rich "Oops!" S.
Old July 19th 04, 01:05 AM
Kyle Boatright
"Rich S." wrote in message
of
time.
Rich "Oops!" S.
Better to leave a dent in the wing than to leave a bucking bar in the wing.
KB
Another antenna question David Wilson Home Built 7 August 12th 04 10:04 PM
Wing in Ground Effect? BllFs6 Home Built 10 December 18th 03 05:11 AM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
Antenna Ground Plane Grounding Fastglasair Home Built 1 July 8th 03 05:21 PM
