How tall are you? If you are not a very tall person you may be having a hard
time seeing over the cowl. The seats are very low in the Mooney since the plane was designed for 6' + individuals. What I like to do with students is to pull onto the runway and sit there lined up with the runway (make sure the CFI is watching for traffic you have your back too!). Really take the time to get used to the picture down the runway with the plane on the ground. Notice where the runway edge intersects your head (probably above your ears). Although some runways are more wide or narrow the runway edge will always intersect your head at the same point (its based only on your hight above the runway). Also, when landing the Mooney understand that if the stall horn isn't even going off you are far, far from landing speed. The Mooney will float and in the begining you can use the stall horn to help determine when you should allow the plane to sink below 3 feet. Anything faster than 65 knots or so should be kept above 3 feet. The Mooney gets very upset if the nose wheel touches first because there are no shocks. Because of the donut's characteristics the nose will push back rather hard and bounce you back into the air. You get 2 bounces for free, the 3rd will cost about $15,000. As long as you control your speed in the Mooney, plan your decents far enough out, and keep ahead of the plane you will find it a very nice, rather easy plane to fly. It does not deserve the neg reputation it has for being hard to fly. -Robert, Mooney CFI "Jon Kraus" wrote in message ... We just purchased a'79 M20J 4443H. I am in the middle of getting my 10 hours with a CFI for Insurance purposes and I have to tell you that this thing is a lot different to land than a Skyhawk. So far I am glad that my CFI has been with me because 75 percent of the landings have not been pretty. They are safe (mostly) but nothing you'd want the wife to film with the video camera. I've got the speeds down good (100 on downwind, 90 on base and 80 on final) but getting it to the runway smoothly has been a challange. I've never flown a low wing plane before the Mooney and I am having a problem with the sight picture working out for me. Is this a pretty common issue in transitioning to these planes or should I just resign to the fact that I'm not going to get as nice a landings in my Mooney as I did in the Skyhawk . Right now any stories would help out tremendously!! Thanks. Jon Kraus PP-ASEL-IA Student Mooney Owner '79 M20J 4443H @ TYQ |
"Robert M. Gary" wrote
Really take the time to get used to the picture down the runway with the plane on the ground. Robert, I go one step further, I get out and hold the tail down in order that the student can see (and hopefully retain) the landing attitude. Bob Moore |
Excellent idea but I'm not sure if I'm strong enough to do that. I've never
noticed the Mooney tending to tip (unlike a 172). You must be a large muscle type of guy. You aren't by chance the governor of California are you? BTW: I find that for tailwheel training its really good to have the student sit in the plane while we lift the tail. Students tend to think that they will hit the prop on a wheel landing (some times you can though). They don't realize that most tailwheels will "tuck" the prop under the plane before it hits the ground. You generally have to tip MUCH more than students think to hit the prop in the tailwheel. -Robert "Bob Moore" wrote in message . 122... "Robert M. Gary" wrote Really take the time to get used to the picture down the runway with the plane on the ground. Robert, I go one step further, I get out and hold the tail down in order that the student can see (and hopefully retain) the landing attitude. Bob Moore |
sit in the plane while we lift the tail. Students tend to think that they will hit the prop on a wheel landing (some times you can though). They don't realize that most tailwheels will "tuck" the prop under the plane before it hits the ground. You generally have to tip MUCH more than students think to hit the prop in the tailwheel. Do you deflate the tires a bit too, to account for flexing during a bounce? Jose -- for Email, make the obvious change in the address note - replied to r.a.piloting, r.a.student, and r.a.owning, but I only follow r.a.p |
Jose wrote in message .com...
Do you deflate the tires a bit too, to account for flexing during a bounce? I'm not too concerned about that since my students know to add full power and climb out of a bounce. The mental challenge for students is to feel ok about pushing forward on the stick after the mains touch to "stick" the wheel landing. Some feel that any forward rotation will result in a prop strike. A bounce is a different thing. -Robert, CFI |
bounce? I'm not too concerned about that since my students know to add full power and climb out of a bounce. My point isn't the bounce, but the fact that the prop is closer to the ground while the tires are compressed and the wheel struts are deflected (to the extent that happens in a Mooney). So the sight picture you give the students would not be exactly accurate. I'm not sure an inch makes a difference in the sight picture they will remember, but it would be an expensive inch. Jose -- for Email, make the obvious change in the address |
I'm not sure I'm strong enough for the tailwheel trick - I guess that
applies to Cubs and such. No one is picking up a Maule tail like that. OTOH, there is much advice warning against wheelies in the Maule. I can do 'em but don't because you don't need 'em. You can fly it on 3 points quite nicely with reduced or neg flaps. Still don't know exactly why but make and model wise, it just doesn't need to be in your kit. Wish I could operate a Mooney off my grass.... "Robert M. Gary" wrote in message ... Excellent idea but I'm not sure if I'm strong enough to do that. I've never noticed the Mooney tending to tip (unlike a 172). You must be a large muscle type of guy. You aren't by chance the governor of California are you? BTW: I find that for tailwheel training its really good to have the student sit in the plane while we lift the tail. Students tend to think that they will hit the prop on a wheel landing (some times you can though). They don't realize that most tailwheels will "tuck" the prop under the plane before it hits the ground. You generally have to tip MUCH more than students think to hit the prop in the tailwheel. -Robert "Bob Moore" wrote in message . 122... "Robert M. Gary" wrote Really take the time to get used to the picture down the runway with the plane on the ground. Robert, I go one step further, I get out and hold the tail down in order that the student can see (and hopefully retain) the landing attitude. Bob Moore |
"Maule Driver" wrote in message . com...
I'm not sure I'm strong enough for the tailwheel trick - I guess that applies to Cubs and such. No one is picking up a Maule tail like that. OTOH, there is much advice warning against wheelies in the Maule. I can do 'em but don't because you don't need 'em. You can fly it on 3 points quite nicely with reduced or neg flaps. Still don't know exactly why but make and model wise, it just doesn't need to be in your kit. The Maule is one of the tailwheels I've not flown. 3pts are nice and a plane's behavior in a 3pt often is related to how close (or far) from stall it is in a 3pt attitude. In the Swift it is recommended that you NOT 3 pt it because the 3pt attitude is so far beyond stalls, most pilots just end up dropping it in (notice that most Swifts have wrinkles on the top of the wings). In some planes you are still totally flying at 3pt attitude (Citabria for example). Wish I could operate a Mooney off my grass.... My Mooney does fine off grass and even beaches (I've flown off a couple in Mexico). The grass just can't be too deep or the holes too deep. Our local grass field (C14) has big gopher holes all over it so I've never taken a nose wheel plane in there. I love taking the Swift, Aeronca, and C140 into that field. The runway threshold has powerlines over it and a giant oak tree hanging over the runway. You can't go below these because its backed up against a levy. Some people land the other direction but then a go-around is suicide. When my kids were young they referred to C14 as "the airport where the planes live in the grass". -Robert |
The TWs are all a little different from what I've heard. The Maule is the
only one I've flown. You really have a choice of 3point configs - Landing flaps will allow you to arrive right at what I'd call "the end of elevator authority". Not quite a stall but you are done unless you add power. On the other hand, take-off flaps, 0 flaps or negative flaps (a Maule feature) allow you to fly it on with authority. All positions approved for landing in the ops manual. I've certainly heard that the Maules handle grass fine. But I'm afraid that my combination of 3300', 50' obstructions both ends, and surface quality makes it a little too tight for regular operations, close to gross, at 95 degrees. I've never completely run the numbers but even with that light early model 21, takeoff would be dicey. Then the wet wing.... and all. Bo's and Commanche's seem to handle it OK but the Mooney seems to push the limits a bit. But I love that wing on it. "Robert M. Gary" wrote in message om... "Maule Driver" wrote in message . com... I'm not sure I'm strong enough for the tailwheel trick - I guess that applies to Cubs and such. No one is picking up a Maule tail like that. OTOH, there is much advice warning against wheelies in the Maule. I can do 'em but don't because you don't need 'em. You can fly it on 3 points quite nicely with reduced or neg flaps. Still don't know exactly why but make and model wise, it just doesn't need to be in your kit. The Maule is one of the tailwheels I've not flown. 3pts are nice and a plane's behavior in a 3pt often is related to how close (or far) from stall it is in a 3pt attitude. In the Swift it is recommended that you NOT 3 pt it because the 3pt attitude is so far beyond stalls, most pilots just end up dropping it in (notice that most Swifts have wrinkles on the top of the wings). In some planes you are still totally flying at 3pt attitude (Citabria for example). Wish I could operate a Mooney off my grass.... My Mooney does fine off grass and even beaches (I've flown off a couple in Mexico). The grass just can't be too deep or the holes too deep. Our local grass field (C14) has big gopher holes all over it so I've never taken a nose wheel plane in there. I love taking the Swift, Aeronca, and C140 into that field. The runway threshold has powerlines over it and a giant oak tree hanging over the runway. You can't go below these because its backed up against a levy. Some people land the other direction but then a go-around is suicide. When my kids were young they referred to C14 as "the airport where the planes live in the grass". -Robert |
![]() "Robert M. Gary" wrote: Students tend to think that they will hit the prop on a wheel landing (some times you can though). They don't realize that most tailwheels will "tuck" the prop under the plane before it hits the ground. My Maule has 9" of ground clearance for the prop tips. The mains are a bit more than 5' behind the prop, so that prop isn't going to "tuck under". The 180hp version has 6" of clearance. This is one of two reasons I've heard for the fact that Maule discourages wheel landings in the MX-7 series. As Maule Driver says, you don't need them anyway. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 06:49 PM |
Landing a Mooney | Jon Kraus | Owning | 42 | November 16th 04 07:00 PM |
VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 05:22 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Off topic - Landing of a B-17 | Ghost | Home Built | 2 | October 28th 03 04:35 PM |
