![]() Simple question. Can I fly the NY VFR corridor in a transponderless aircraft that meets the exception requirements of 91.215 (no electrical system)? It looks like the answer is yes, provided I stay low enough (below 500' as I turn the Lady). Any new TFR or other restrictions on this? Any good intros on doing it (freq's. suggested reporting points, etc.) Thanks. I'm not so sure about transponder-less a/c inside the 30 nm ring. I would check on that. But, if so, the frequency is 123.05 on the Hudson River. Self-announce position, stay right (as a highway). www.Rosspilot.com |
You cannot enter 30nm ring without a transponder. However, I think you can
get a special permission from FSDO to enter or leave without transponder for good reasons. I dont think they will give you a permission because you want to fly into that corridor without a transponder. Toks Desalu Dyin' to soar PP-ASEL "Rosspilot" wrote in message ... Simple question. Can I fly the NY VFR corridor in a transponderless aircraft that meets the exception requirements of 91.215 (no electrical system)? It looks like the answer is yes, provided I stay low enough (below 500' as I turn the Lady). Any new TFR or other restrictions on this? Any good intros on doing it (freq's. suggested reporting points, etc.) Thanks. I'm not so sure about transponder-less a/c inside the 30 nm ring. I would check on that. But, if so, the frequency is 123.05 on the Hudson River. Self-announce position, stay right (as a highway). www.Rosspilot.com |
![]() "Toks Desalu" wrote in message ... You cannot enter 30nm ring without a transponder. You can in an airplane that has never had an engine-driven electrical system. |
![]() Toks Desalu wrote: You cannot enter 30nm ring without a transponder. However, I think you can get a special permission from FSDO to enter or leave without transponder for good reasons. I dont think they will give you a permission because you want to fly into that corridor without a transponder. You get it from TRACON if your aircraft has an electrical system. The reason can be as simple as "I want to fly through there on my way to xxx". Getting permission to actually enter the class-B is another kettle of fish, but I've heard of it being arranged. As far as aircraft without electrical systems goes, FAR 91.215 states in part -- (3) Notwithstanding paragraph (b)(2) of this section, any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon or glider may conduct operations in the airspace within 30 nautical miles of an airport listed in appendix D, section 1 of this part provided such operations are conducted -; (i) Outside any Class A, Class B, or Class C airspace area; and (ii) Below the altitude of the ceiling of a Class B or Class C airspace area designated for an airport or 10,000 feet MSL, whichever is lower; and Despite that last "and", there is no part iii in the copy of the FARs on the AOPA web site. As I read that, he can run the corridor if he wants to. That's outside the class B airspace. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
"G.R. Patterson III" wrote:
As I read that, he can run the corridor if he wants to. That's outside the class B airspace. That's how I read it too. Anyone do this? Anyone have a terminal chart and can verify that I'd have to go to 500' or lower, or is there a sliver of 70/11 or higher east of the Lady that I can't see? |
![]() Mike wrote: That's how I read it too. Anyone do this? Anyone have a terminal chart and can verify that I'd have to go to 500' or lower, or is there a sliver of 70/11 or higher east of the Lady that I can't see? Most of NY harbor is under an 1,100' floor. This extends from the Jersey shore just to the west of the Lady nearly to Brooklyn. There's a sliver of 1,500' floor along the Brooklyn shore that extends to the Holland tunnel. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
terminal chart and can verify that I'd have to go to 500' or lower, or is there a sliver of 70/11 or higher east of the Lady that I can't see? On the NY Terminal chart I have, there is a sliver of 70/+11 over the bay. The statue of liberty appears to be within that sliver (though at the edge of a 70/+05 piece, so I wouldn't circle it). The bottom of the Hudson (North of the Lady) is 70/15 left over from Brooklyn, the middle of the Hudson is 70/+11, and a bit North of the Washington Bridge you get 70/15 again until halfway to the TZ bridge, where it's 70/30. Going South, near the VZ Bridge it's 70/15, so if you stay below 1000 you'll be outside the class B. It's a nice trip. I do highly reccomend radio contact with other aircraft, so grab a handheld, listen, and self-announce. Jose -- for Email, make the obvious change in the address |
One of the pilots at SMQ used to run the corridor in his Champ. No Xponder
there. I'll ask him about it when I see him next. -- Bob (Chief Pilot, White Knuckle Airways) I don't have to like Bush and Cheney (Or Kerry, for that matter) to love America "G.R. Patterson III" wrote in message ... Toks Desalu wrote: You cannot enter 30nm ring without a transponder. However, I think you can get a special permission from FSDO to enter or leave without transponder for good reasons. I dont think they will give you a permission because you want to fly into that corridor without a transponder. You get it from TRACON if your aircraft has an electrical system. The reason can be as simple as "I want to fly through there on my way to xxx". Getting permission to actually enter the class-B is another kettle of fish, but I've heard of it being arranged. As far as aircraft without electrical systems goes, FAR 91.215 states in part -- (3) Notwithstanding paragraph (b)(2) of this section, any aircraft which was not originally certificated with an engine-driven electrical system or which has not subsequently been certified with such a system installed, balloon or glider may conduct operations in the airspace within 30 nautical miles of an airport listed in appendix D, section 1 of this part provided such operations are conducted -; (i) Outside any Class A, Class B, or Class C airspace area; and (ii) Below the altitude of the ceiling of a Class B or Class C airspace area designated for an airport or 10,000 feet MSL, whichever is lower; and Despite that last "and", there is no part iii in the copy of the FARs on the AOPA web site. As I read that, he can run the corridor if he wants to. That's outside the class B airspace. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
Toks Desalu wrote:
You cannot enter 30nm ring without a transponder.... This statement is incorrect. You need to review FAR 91.215, section b (3). It states that the original request is legal (flight within the 30 mile Mode C veil, but NOT within the Class B), since the OP clearly stated that the aircraft in question not only had no transponder, but no electrical system. This says nothing about the whether it's a good idea to fly NORDO within the corridor - I'd be a bit hesitant. However, with a HANDHELD radio, you'd be perfectly safe (at least as safe as everyone else) and perfectly legal. -- Marc J. Zeitlin http://marc.zeitlin.home.comcast.net/ http://www.cozybuilders.org/ Copyright (c) 2004 |
![]() "Marc J. Zeitlin" wrote in message news:jtuid.55136$R05.36410@attbi_s53... Toks Desalu wrote: You cannot enter 30nm ring without a transponder.... This statement is incorrect. You need to review FAR 91.215, section b (3). It states that the original request is legal (flight within the 30 mile Mode C veil, but NOT within the Class B), since the OP clearly stated that the aircraft in question not only had no transponder, but no electrical system. This says nothing about the whether it's a good idea to fly NORDO within the corridor - I'd be a bit hesitant. However, with a HANDHELD radio, you'd be perfectly safe (at least as safe as everyone else) and perfectly legal. How does a handheld radio make you as safe as everyone else? |
Old ADF and XPNDR parts | Ben Smith | Owning | 12 | January 18th 04 09:36 PM |
