"Ramapriya" wrote in message
om... Is a non-aviator airing a doubt ok with you folks? Sure. I know cars and trucks tend to skid even at low speeds in sleet and on ice, with braking often proving ineffectual. This leaves me wondering why is it that we don't ever hear of aircraft skidding and going off-track while taxiing or even during takeoff/landing? Perhaps you just aren't receiving your information from sources that would mention such an event. Is the lack of such incidents only because of the meticulousness of ice clearance by airport authorities? At some airports, yes. Generally, the more important an airport is to the national transportation system (and all airports are important at least to some degree), the better quality of maintenance, including keeping the pavement clear of snow and ice. Some of the largest airports even have heated runways, I believe. Even so, once in a very long while, an airliner does wind up skidding off the runway or taxiway somewhere. I don't know the exact frequency, but probably on the order of once a decade or so. At smaller airports, this happens more frequently, but as with cars, it rarely involves more than some bent sheet metal. Accidents are likely to be low speed (almost all taxiing happens at relatively low speeds...5-10mph at most), and those that happen on landing (i.e. at higher speed) often don't wind up in the news because they happened at the airport, rather than somewhere that would make for something that sells ads on the evening news (like a residential neighborhood). Another factor is that airplanes have more to control them than just the tires. In particular, the faster the airplane is going, the more likely the same surfaces used to control the airplane in the air can also be used to control the airplane on the ground. Just as a "for example", I landed at the Reno, NV airport once on a VERY hot day, while flying a small four-seater single-engine airplane. I landed on the same runway that the big airliners use, and touched down in the same spot that they do. Well, it turns out that when they touch down, each one leaves a little rubber. By the time I'd arrive, there was a WHOLE LOT of rubber, at a very high temperature. It was as slick as any ice, perhaps slicker. I had no braking whatsoever. But I didn't lose control of the airplane, because I still had plenty of rudder control to keep me going in the right direction. I simply "flew" the airplane while on the ground, until I got to the pavement that was clear, made a normal stop and taxied off the runway. This same effect helps prevent takeoff accidents...long before the airplane leaves the ground, the tires are no longer required to keep the airplane aligned with the runway. Rudder control is perfectly sufficient, especially on a runway that is nice and flat. Of course, all of the things that "cwk" mentions are relevant too. The bottom line is that it's not actually true that airplanes don't have trouble with ice, but it IS true that there are reasons those issues come up less frequently than they might with automobiles. Pete |
Introduction to a newbie | Shane O | Aerobatics | 9 | December 31st 04 06:13 AM |
Questions from a newbie. | Andrew Tubbiolo | Home Built | 9 | September 14th 04 01:40 AM |
Iran does not doubt Bush's stupidity but... | Matt Wiser | Military Aviation | 3 | February 16th 04 06:22 PM |
Newbie questions Rail / Ejector launchers | AL | Military Aviation | 19 | November 14th 03 07:47 PM |
Basic Stupid Newbie Questions... | John Penta | Military Aviation | 5 | September 19th 03 05:23 PM |
