Instrument mounting question
Old July 19th 04, 07:51 PM
Joe Vasher
"Rob Turk" wrote in message l.nl...
I'm looking for some guidance on safely mounting instruments in an alumimium
panel. Our panel is about 2mm (about 1/12th inch) thick. We had all the
shapes laser cut, so everything fits well.
What do most of you do with deep, heavy instruments like a gyro? Is it safe
to just use the screws on the front or do most of you add some form of
support at the back of the instrument to support the weight? If so, what
construction did you use?
Thanks,
Rob
Hi Rob,
My suggestion is to face mount, mount the pannel using rubber mounts
(shock mounts) and choose your instruments accordling.
Instrument Question Dick Home Built 10 May 30th 04 12:05 AM
Aluminum instrument panel finish? Richard Riley Home Built 31 February 4th 04 02:09 AM
Question for Squirrel the Lurker jls Home Built 0 January 30th 04 02:41 PM
Tecumseh Engine Mounting Question jlauer Home Built 7 November 16th 03 01:51 AM
