A very basic question
Old November 6th 04, 07:31 PM
Andrew Sarangan
" jls" wrote in news:758jd.40492$T_.36816
@bignews4.bellsouth.net:
"James Robinson" wrote in message
Ramapriya wrote:
... why does the banking of wings by the use of ailerons not just
roll an aircraft but also produces a turn (yaw)?
Simply stated, when an aircraft is in level flight, the lift of the
wings works directly against gravity. When an aircraft rolls one
direction or the other, the lift of the wings rolls away from vertical,
remaining at 90 degrees to the wings. This means only part of the lift
works against gravity. The rest causes the aircraft to swing away from
straight flight. It is somewhat akin to the effect of banking on a race
track.
Fair enough. The turn is caused by the horizontal component of lift.
Sure, but that still does not explain why the airplane turns. A horizontal
component of lift will make the airplane side-slip, not turn. It is the
stability (weathervane effect) that makes the airplane turn.
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old November 7th 04, 11:23 AM
Hilton
By definition, the 'weathervane effect' occurs because air exerts more
pressure on one side of the object (aircraft) than the other - same
definition as slipping. Therefore, are you are asserting that an aircraft
turns because it is slipping? More over, it will only turn if it is
slipping?
Hilton
Old November 7th 04, 03:26 PM
Andrew Sarangan
"Hilton" wrote in
ink.net:
horizontal component of lift will make the airplane side-slip, not
turn. It is the stability (weathervane effect) that makes the
airplane turn.
aircraft turns because it is slipping? More over, it will only turn
if it is slipping?
Hilton
Think of the space shuttle. If you fire rockets horizontal to the flight
path, the shuttle will slide sideways. It will not turn the nose towards
the direction of travel. An airplane turns because it wants to point the
nose into the relative wind.
Old November 8th 04, 09:21 AM
Hilton
Andrew,
airplane turn.
if it is slipping?
Hilton
I understand that, but you never answered my question: "Are you asserting
that an aircraft turns because it is slipping (weathervaning)?"
Hilton
Old November 9th 04, 03:51 AM
Andrew Sarangan
Yes, my understanding is that a bank causes an airplane to slip, which
then causes it to weathervane into the wind. Why do you ask? Is there
something I am missing?
"Hilton" wrote in news:lUGjd.8614$O11.3080
@newsread3.news.pas.earthlink.net:
Andrew,
airplane turn.
more
turn
if it is slipping?
Hilton
flight
towards
asserting
Hilton
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Phoenix AIM-54A (QUESTION) Krztalizer Naval Aviation 10 February 23rd 04 07:22 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 05:23 PM
