I wonder how the NTSB on this one will read...
Old November 7th 04, 01:00 PM
Dave S
Default I wonder how the NTSB on this one will read...
http://www.chron.com/cs/CDA/ssistory...olitan/2888090
Plane lands in field near runway
A two-engine plane landed on its belly in a grassy field next to the
runway at Weiser Air Park in northwest Harris County on Saturday. The
pilot was able to land the plane after the left-wing wheel fell off,
according to the Cy-Fair Volunteer Fire Department. No one was injured
in the landing.
KEYQ in Houston is Weiser
Dave
Old November 7th 04, 02:54 PM
NW_PILOT
"Dave S" wrote in message
ink.net...
in the landing.
Dave
I would think Grass is better than the pavement with no wheels or one
missing
Old November 7th 04, 03:11 PM
Richard Hertz
"NW_PILOT" wrote in message
ink.net...
in the landing.
Dave
missing
Some disagree - saying you can skid on hard surface - grass/turf allows
something to dig in and coming to a dangerously quick halt rather than
dissipating energy over more time.
Old November 7th 04, 03:13 PM
Larry Dighera
On Sun, 7 Nov 2004 06:54:55 -0800, "NW_PILOT" wrote
in ::
missing
Better for what? While a gear-up landing on grass may result in less
aluminum loss, it increases the hazard of flipping.
Old November 7th 04, 03:47 PM
Tobias Schnell
On Sun, 07 Nov 2004 13:00:25 GMT, Dave S
Isn't TwinCo-Michael flying out of Weiser?
Regards
Tobias
Old November 7th 04, 03:59 PM
C J Campbell
missing
It is much worse. Grass can hide potholes and rocks. The nose of the
airplane can dig into the soft dirt and flip the plane over. A wing can dig
in and cause a ground loop. Dry grass is just one more thing that can catch
fire.
Airplanes that land gear up on pavement usually suffer minimal damage,
especially if the engine is stopped and the propeller is horizontal. Damage
is often limited to some scrapes on the belly and wingtips.
Old November 7th 04, 04:39 PM
Ron Natalie
I've seen the results of people landing Navion's on dry pavement. If
you keep the wings level you pertty much just loose the step, the flap
hinge and whatever antennas are sticking out the bottom.
Old November 7th 04, 06:31 PM
Dale
Over the years I watched aircraft Cardinals and Arrows up through King
Airs, C-82s and 727s land gear up on pavement. Not once was there a
fire or extensive damage to the aircraft. There was another King Air
that landed gear up. The decision was made to blow snow back onto the
runway for him to set the airplane down in. Bad idea. It damage the
engine intakes, ripped panels of the wing and belly, lots of damage
compared to something landing on pavement.
If it happens to me I'm finding a long, wide strip of pavement somewhere
to put the airplane.
Dale L. Falk
Old November 8th 04, 03:18 AM
Capt.Doug
"NW_PILOT" wrote in message I would think Grass is better than the
pavement with no wheels or one missing
No. The grass and dirt under you are not uniform in density. The airframe
will slide over a section of soft dirt and sink. Then the airframe will
slide into a section of hard dirt and stop suddenly. Sudden deceleration is
your enemy. Hard surfaces are much better for belly landings. Most
fire-rescue departments don't foam runways anymore to keep the slide to a
minimum so you don't slide off the side of the runway into the grass.
D.
Old November 8th 04, 06:30 AM
Tina Marie
Yes, but it wasn't Michael. It wasn't a twin, it wasn't a gear-up landing,
and it wasn't a grassy field next to the runway.
It was a Warrior (something-92C), the left main fell apart on takeoff
from West Houston, they brought it back to Weiser, where they did
a picture-perfect landing on the grass runway. CFI and student.
Tina Marie
(also based at EYQ)
http://www.tripacerdriver.com "...One of the main causes
of the fall of the Roman Empire was that, lacking zero, they had no way
to indicate successful termination of their C programs." (Robert Firth)
Ye
NTSB: USAF included? Larry Dighera Piloting 10 September 11th 05 10:33 AM
Get Over $50,000 Fast and Easy, READ HOW [email protected] Owning 0 January 1st 05 04:41 PM
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
OT - What espioange/war novels do you read? [SURVEY] Eric Pinnell Military Aviation 34 April 28th 04 06:23 PM
12 Dec 2003 - Today’s Military, Veteran, War and National Security News Otis Willie Naval Aviation 0 December 12th 03 11:01 PM
