Garmin 430 wierd issues
Old November 8th 04, 12:11 AM
iflyatiger
Jon
I do not have access to my 530 right now to confirm what I will tell you
but..
It sound sounds to me like you might not be tuned to the correct exact
frequency.
There is a setting in the setup 2 page of the 430 called COM configuration
were you can set the channel spacing I wonder if this could be set wrong.
Hope it help..
Jon
"Jon Kraus" wrote in message
My partner and I just bought a '79 Mooney M20J with a 2 year old Garmin
430 Comm/Nav as the Comm # 1 adn a Bendix 170B as the Comm/Nav # 2. (yes
we had a pre-buy and everything "seemed" fine") I have some strange
issues with the 430 that I am sure you can help guide me thru. Issues:
1.) On the ground if you set the 430 to our UNICOM freq TYQ 123.05 and
do a radio check they can not hear you. TYQ has an AWOS and you can hear
that fine on the ground (120.725).
2.) On the ground if you set the 170B (nav/com # 2) and do a radio check
they come back as "loud and clear" (and yes they are at the station when
I try the radio check on comm 1) :-)
3.) One time we were on the ground set up on the Comm 1 and trying to
get the UNICOM operator to hear us when a Piper over the airport said we
were "loud and clear".
4.) Our local UNICOM is 123.05. UMP an airport 15 miles away's UNICOM
is 123.00. While airborn we kept picking up their transmissions.
I was going to try swapping antenna connections between Comm 1 and Comm
2 but as I peered under the dash looking for the antenna leads I said
"I'll screw more up then I'll ever fix so I left it alone)
Any suggestions or advise? Is this going to cost a fortune to fix?
Thanks in advance for your help!!
Jon Kraus
PP-ASEL-IA
Student Mooney Owner
4443H @ TYQ
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Garmin 430 wierd issues Jon Kraus Owning 6 November 12th 04 02:07 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
How much could I get for these back issues? Aaron Smith Home Built 8 December 15th 03 12:07 PM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
