Garmin 430 wierd issues
Old November 8th 04, 01:06 AM
Mike Rapoport
First check that the TX annunciator comes on the 430 when you transmit. It
is right there with the COM frequencies in the upper left corner. If the
annunciator is coming on then check the antenna. I assume that you can hear
on 123.05?
Mike
MU-2
"Jon Kraus" wrote in message
My partner and I just bought a '79 Mooney M20J with a 2 year old Garmin
430 Comm/Nav as the Comm # 1 adn a Bendix 170B as the Comm/Nav # 2. (yes
we had a pre-buy and everything "seemed" fine") I have some strange issues
with the 430 that I am sure you can help guide me thru. Issues:
1.) On the ground if you set the 430 to our UNICOM freq TYQ 123.05 and do
a radio check they can not hear you. TYQ has an AWOS and you can hear that
fine on the ground (120.725).
2.) On the ground if you set the 170B (nav/com # 2) and do a radio check
they come back as "loud and clear" (and yes they are at the station when I
try the radio check on comm 1) :-)
3.) One time we were on the ground set up on the Comm 1 and trying to get
the UNICOM operator to hear us when a Piper over the airport said we were
"loud and clear".
4.) Our local UNICOM is 123.05. UMP an airport 15 miles away's UNICOM is
123.00. While airborn we kept picking up their transmissions.
I was going to try swapping antenna connections between Comm 1 and Comm 2
but as I peered under the dash looking for the antenna leads I said "I'll
screw more up then I'll ever fix so I left it alone)
Any suggestions or advise? Is this going to cost a fortune to fix? Thanks
in advance for your help!!
Jon Kraus
PP-ASEL-IA
Student Mooney Owner
4443H @ TYQ
Old November 8th 04, 12:10 PM
Jon Kraus
Yes I can receive (hear) on 123.05 and the "TX" shows up as I push the
"press to talk" switch. Just UNICOM can not hear me from the ground.
Unfortunatly the only freq on this airport is the UNICOM 123.05 and the
AWOS which is 120.725.
on 123.05?
Mike
MU-2
"loud and clear".
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Old November 11th 04, 11:50 PM
Marty from Sunny Florida
If you hit the PTT and your antenna is not correctly connected to the 430,
you can damage the 430. I'd have a radio guy look at it before messing
around too much. On occasion, just looking can do some damage.
Just a thought ...
Marty from Sunny South Florida
It
hear
on 123.05?
Mike
MU-2
issues
do
that
I
get
were
"loud and clear".
is
2
"I'll
Thanks
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Old November 12th 04, 02:07 AM
Jon Kraus
The Avionics shop discovered that the comm side board is bad. It has to
go back to Garmin for the $600.00 refurb.... JK
Just a thought ...
It
hear
on 123.05?
Mike
MU-2
issues
do
that
I
get
were
"loud and clear".
is
2
"I'll
Thanks
Jon Kraus
PP-ASEL-IA
4443H @ TYQ
Amateur Review of the Garmin GPSMAP 296 GPS Rhett Piloting 10 March 23rd 05 01:16 AM
Garmin 430 wierd issues Jon Kraus Owning 6 November 12th 04 02:07 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
How much could I get for these back issues? Aaron Smith Home Built 8 December 15th 03 12:07 PM
Garmin 90 Database Updates Discontinued Val Christian Piloting 14 August 20th 03 09:32 PM
