A very basic question
Old November 8th 04, 07:30 PM
Mike Rhodes
On Sat, 06 Nov 2004 22:22:22 GMT, Mike Rhodes
A banked aircraft will not turn if, and only if, the wing is not
generating lift. A wing will not generate lift if its angle of attack
is so controlled by the horizontal stabilizer.
I was not quite right with the "if and only if". Of course the rudder
can also stop the turn, as in a side-slip. And the side-slip Peter
mentioned is what pushes the nose around in the turn by its push on
vertical stabilizer. I did not point directly at the vert stabilizer
as Peter did in his reply.
Because the banked aircraft is aligned less with gravity, it would
then want to accelerate 'up', as 'up' is relative to the aircraft.
But this would immediately change the angle-of-attack of the both the
wing and the horizontal stab. So the wing loses some lift, while the
horizontal stab increases its already downward push. This would tend
to push the nose 'up', and restore the angle of attack of the wing.
The turn is a relatively slow process (the pilot has time to make
adjustments), and maybe the mechanics are not so simple as I think my
post implied.
--Mike
Old November 8th 04, 08:47 PM
Mike Rhodes
On Mon, 08 Nov 2004 19:30:24 GMT, Mike Rhodes
Oops. I got this wrong. If both wing and horizontal stab are pushed
down then the net effect is no change in angle of attack.
--Mike
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Phoenix AIM-54A (QUESTION) Krztalizer Naval Aviation 10 February 23rd 04 07:22 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 05:23 PM
