Parallax is the scientific term for relative displacement of objects
observed at different distances. Parallax is used often by astronomers to ascertain the distance of objects within our own solar system, and even nearby stars by observing them from different points in the earth's orbit around the sun. I the case of the turn coordinator, the reason the ball appears off center when observed from the side is due to parallax. This does not mean that this is the only instance in which the concept of parallax is applied. The original poster described another circumstance that results from parallax; i.e. a moving object appearing to be stationary when compared to the background when the observer is also moving at a rate and in a direction that allows the parallax to create the illusion that the airplane is stationary when in fact it is not... I just wanted to point out to the group that this is a well known phenomenon that has a scientific term to describe it. Dean Wilkinson "Robert M. Gary" wrote in message om... "Dean Wilkinson" wrote in message ... Its called parallax. Your motion, the motion of the plane, and the background were in the right configuration so that the parallax made the plane appear to be stationary when in fact it was not... Are you sure? Parallax is when you try to show a student how to make a coordinated turn and you end up with the ball out to the left because you aren't looking at the turn coordinator straight on. -Robert, CFI |
Rental policy | Robert | Piloting | 83 | May 13th 04 05:29 PM |
I need some advice on buying my own plane BEFORE training... | Anthony L | Piloting | 6 | April 22nd 04 11:13 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | September 1st 03 07:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | August 1st 03 07:27 AM |
