I had a minute so I looked this up; you misread the AIM.
4-4-10. IFR SEPARATION STANDARDS b. Separation will be provided (by ATC - my note) between all aircraft operating on IFR flight plans except during that part of the flight (outside of Class B airspace or a TRSA) being conducted on a VFR-on-top/VFR conditions clearance. Under these conditions, ATC may issue traffic advisories, but it is the sole responsibility of the pilot to be vigilant so as to see and avoid other aircraft. To paraphrase and clarify: If you are "outside of Class B airspace or a TRSA" and flying on a "VFR-on-top/VFR conditions clearance", "ATC may issue traffic advisories, but it is the sole responsibility of the pilot to be vigilant so as to see and avoid other aircraft". Otherwise, "Separation will be provided (by ATC - my note) between all aircraft operating on IFR flight plans". "Peter R." wrote in message ... Bill Denton ) wrote: And I don't know if this is a trick question, but if you are at 6000 (no +500) wouldn't you be on an IFR flight plan, talking to ATC, and receiving traffic advisories? In the US and outside of class B airspace, it is the pilot, not ATC, who is ultimately responsible for IFR/VFR traffic separation. A VFR traffic advisory to an IFR aircraft is a courtesy offered by ATC; it is not a guarantee. -- Peter |
I had a minute so I looked this up; you misread the AIM. You and I have been through this before. The AIM is not regulatory and perhaps you might want to re-read that passage. It appears to me that you have misinterpreted it. Let's break this down: b. Separation will be provided (by ATC - my note) between all aircraft operating on IFR flight plans except during that part of the flight (outside of Class B airspace or a TRSA) being conducted on a VFR-on-top/VFR conditions clearance. Please show me where in that passage above does it say anything about IFR aircraft being separated from VFR aircraft. Note the operative word "between" being used there. I interpret the passage to be discussing IFR aircraft being separated from IFR aircraft. To paraphrase and clarify: If you are "outside of Class B airspace or a TRSA" and flying on a "VFR-on-top/VFR conditions clearance", "ATC may issue traffic advisories, but it is the sole responsibility of the pilot to be vigilant so as to see and avoid other aircraft". Otherwise, "Separation will be provided (by ATC - my note) between all aircraft operating on IFR flight plans". There, you stated it, too. "BETWEEN all aircraft operating on IFR flight plans." Where does it say anything about ATC's responsibility about separation between those aircraft on IFR flight plans and those on VFR flight plans? Not in that passage it doesn't. -- Peter |
My comments in text:
"Peter R." wrote in message ... Bill Denton ) wrote: I had a minute so I looked this up; you misread the AIM. You and I have been through this before. The AIM is not regulatory and perhaps you might want to re-read that passage. It appears to me that you have misinterpreted it. Regulatory/no-regulatory is immaterial. This portion of the AIM simply states what services will be offered to pilots by ATC. Let's break this down: b. Separation will be provided (by ATC - my note) between all aircraft operating on IFR flight plans except during that part of the flight (outside of Class B airspace or a TRSA) being conducted on a VFR-on-top/VFR conditions clearance. Please show me where in that passage above does it say anything about IFR aircraft being separated from VFR aircraft. Note the operative word "between" being used there. I interpret the passage to be discussing IFR aircraft being separated from IFR aircraft. The separation of VFR/IFR aircraft is not covered in this section; the separation of ALL aircraft is discussed in the previous section. The purpose of this section is to remind VFR-on-top-pilots that while they are on an IFR flight plan, ATC has allowed them to deviate and fly under VFR rules (including see and avoid) and that ATC is not obligated to provide traffic guidance. To paraphrase and clarify: If you are "outside of Class B airspace or a TRSA" and flying on a "VFR-on-top/VFR conditions clearance", "ATC may issue traffic advisories, but it is the sole responsibility of the pilot to be vigilant so as to see and avoid other aircraft". Otherwise, "Separation will be provided (by ATC - my note) between all aircraft operating on IFR flight plans". There, you stated it, too. "BETWEEN all aircraft operating on IFR flight plans." Where does it say anything about ATC's responsibility about separation between those aircraft on IFR flight plans and those on VFR flight plans? Not in that passage it doesn't. As I stated above, VFR-on-top operations are conducted on IFR flight plans and the purpose of this section is to explain the services to be provided or not provided by ATC to VFR-on-top pilots. -- Peter |
The separation of VFR/IFR aircraft is not covered in this section; the separation of ALL aircraft is discussed in the previous section. Then why are you and I having this disagreement? You asked about separation of an aircraft flying at 6,000 feet, presumably on an IFR flight plan, I maintained all along about the fact that IFR flights are not separated from VFR flights and presented two scenarios where an IFR aircraft at 6,000 feet might encounter a VFR aircraft, yet you quote a passage that admittedly has nothing to do with my posts. The purpose of this section is to remind VFR-on-top-pilots that while they are on an IFR flight plan, ATC has allowed them to deviate and fly under VFR rules (including see and avoid) and that ATC is not obligated to provide traffic guidance. I am not sure what your point about VFR-on-top is, but as a reminder to you, in the US VFR-on-TOP is a specific IFR clearance that must be requested. Simply being on an IFR flight plan in visual conditions is not the same as VFR-on-top. In the case of the IFR flight in VMC, the pilot is still guaranteed ATC separation between other IFR aircraft, but not VFR aircraft (excluding class B). Thus, to your question in your first post, an IFR aircraft at 6,000 feet is still at risk of a mid-air collision. -- Peter |
![]() "Peter R." wrote in message ... Bill Denton ) wrote: The separation of VFR/IFR aircraft is not covered in this section; the separation of ALL aircraft is discussed in the previous section. Then why are you and I having this disagreement? You asked about separation of an aircraft flying at 6,000 feet, presumably on an IFR flight plan, I maintained all along about the fact that IFR flights are not separated from VFR flights and presented two scenarios where an IFR aircraft at 6,000 feet might encounter a VFR aircraft, yet you quote a passage that admittedly has nothing to do with my posts. No, the orignal poster presented the scenario. I simply pointed out that a 6000 feet he would be on an IFR flight plan, talking to ATC, and receiving traffic from ATC. You introduced the passage and misinterpreted it. I provided a correct interpretation. The purpose of this section is to remind VFR-on-top-pilots that while they are on an IFR flight plan, ATC has allowed them to deviate and fly under VFR rules (including see and avoid) and that ATC is not obligated to provide traffic guidance. I am not sure what your point about VFR-on-top is, but as a reminder to you, in the US VFR-on-TOP is a specific IFR clearance that must be requested. And if you are granted that clearance, you will be flying under what are essentially Visual Flight Rules, you will be allowed to deviate from your as-filed flight plan, and ATC is not obligated to provide traffic guidance outside of Class B's and TRSA's.They still have an open IFR flight plan; they must either cancel IFR, or they must rejoin that flight plan at a waypoint on the plan and continue fllying that flight plan. Simply being on an IFR flight plan in visual conditions is not the same as VFR-on-top. In the case of the IFR flight in VMC, the pilot is still guaranteed ATC separation between other IFR aircraft, but not VFR aircraft (excluding class B). Thus, to your question in your first post, an IFR aircraft at 6,000 feet is still at risk of a mid-air collision. But a pilot flying on a VFR flight plan is required to observe "see and avoid", and if he is observing it and taking appropriate evasive action, a collision cannot occur. Keep in mind that separation is not provided only by ATC traffic guidance and "see and avoid", it's also provided by "east is odd, west is even, VFR +500" altitudes and other things. -- Peter |
No, the orignal poster presented the scenario. I simply pointed out that a 6000 feet he would be on an IFR flight plan, talking to ATC, and receiving traffic from ATC. 6,000 feet guarantees an IFR flight plan? Really? You had better notify the FAA about all those VFR pilots who fly around Denver, CO. You introduced the passage and misinterpreted it. I provided a correct interpretation. OK, Bill, you win. Your string of non sequiturs throughout this portion of the thread has worn me out. I have no idea what passage you think I introduced, as in reality I didn't introduce any passage in this thread, but nonetheless, you win. I didn't think you were a troll, since you are a regular in this and other aviation forums, but your self-admitted lack of any real aviation experience combined with your talent to post with such authority and conviction now make me wonder. -- Peter |
An even number of hundreds of feet is reserved for IFR flights (5,000 or
6,000). VFR flights must be +500 (5,500 or 6,000). If you see someone breaking the rules by flying VFR at 6,000 feet you should report them; it's your safety that's at stake. This is not a matter of winning an losing, it's a matter of learning the rules and assuring everyone's safety. And it's not a matter of aviation experience or the lack thereof. Very few ATC controllers actually know how to fly. But we all read the same AIM, and while it can sometimes be confusing, if you look at things in the larger context you can usually make sense out of it. And if that fails, you can always phone or email your local FSDO with any questions (which I frequently do), I've always gotten very prompt answers. As far as my "talent to post with such authority and conviction" goes, I've been a professional writer most of my life; that's the way professional writers write. But just because I write with "authority and conviction" doesn't mean I'm always right. And I've been married and divorced four times; I had more arguments than any man needs. I'm certainly not looking for another. I'm here to learn and contribute what I can; that's all. "Peter R." wrote in message ... Bill Denton ) wrote: No, the orignal poster presented the scenario. I simply pointed out that a 6000 feet he would be on an IFR flight plan, talking to ATC, and receiving traffic from ATC. 6,000 feet guarantees an IFR flight plan? Really? You had better notify the FAA about all those VFR pilots who fly around Denver, CO. You introduced the passage and misinterpreted it. I provided a correct interpretation. OK, Bill, you win. Your string of non sequiturs throughout this portion of the thread has worn me out. I have no idea what passage you think I introduced, as in reality I didn't introduce any passage in this thread, but nonetheless, you win. I didn't think you were a troll, since you are a regular in this and other aviation forums, but your self-admitted lack of any real aviation experience combined with your talent to post with such authority and conviction now make me wonder. -- Peter |
![]() Bill Denton wrote: I am not sure what your point about VFR-on-top is, but as a reminder to you, in the US VFR-on-TOP is a specific IFR clearance that must be requested. And if you are granted that clearance, you will be flying under what are essentially Visual Flight Rules, you will be allowed to deviate from your as-filed flight plan, No. You must follow the flight plan just as if you were regular IFR. Slight deviations for cloud clearance are OK. If you want a different route then you must ask for and receive a new clearance. |
"Cloud clearance" was what I was referring to; sorry for my lack of
clarity... "Newps" wrote in message ... Bill Denton wrote: I am not sure what your point about VFR-on-top is, but as a reminder to you, in the US VFR-on-TOP is a specific IFR clearance that must be requested. And if you are granted that clearance, you will be flying under what are essentially Visual Flight Rules, you will be allowed to deviate from your as-filed flight plan, No. You must follow the flight plan just as if you were regular IFR. Slight deviations for cloud clearance are OK. If you want a different route then you must ask for and receive a new clearance. |
![]() "Newps" wrote in message ... No. You must follow the flight plan just as if you were regular IFR. Slight deviations for cloud clearance are OK. If you want a different route then you must ask for and receive a new clearance. IFR "VFR on top" routing remains the same but you fly at VFR altitudes (cardinal altitude plus 500) of your choice while remaining in VMC. Allen |
Can GPS be *too* accurate? Do I need some XTE?? | Icebound | Instrument Flight Rules | 82 | November 22nd 04 08:01 PM |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
How accurate was B-26 bombing? | ArtKramr | Military Aviation | 59 | March 3rd 04 10:10 PM |
Local TV News ran an accurate story about airframe icing last night | Peter R. | Piloting | 5 | January 29th 04 01:01 AM |
VOR and reverse sensing | Koopas Ly | Piloting | 40 | August 25th 03 01:26 AM |
