"Icebound" wrote in message ...
In the "good old" VOR days, it must have been pretty difficult to fly down the centerline of an airway (or of any direct track). So an eastbound VFR/IFR aircraft descending from 7500/7000 to his destination, was more than likely to avoid traffic... on the reciprocal track passing him by at 6500 or 6000... by some significant horizontal error-distance, even if they didn't see each other (big sky theory :-) ). GPS horizontal accuracy with WAAS is already in the order of magnitude of a Cessna's wingspan, and some are talking about getting it down to mere inches. So the question is: If my Westbound Cessna at 6000 feet (with the autopilot keeping it happily on the GPS-track centerline) meets the descending Bonanza on the reciprocal track between the same two airports (using a similar GPS/a-p combo), there is a distinct possibility that the horizontal clearance may be zero... ...so is there anything in the current crop of GPS and/or Autopilot systems that allow me to maintain a small cross-track error of my choosing, without actually entering off-navaid-off-airport waypoints? ...or do we care; am I overly concerned??? ******************************************** Way overly concerned. I've been flying nearly 50 years, logged over 21,700 hours in general aviation, done a lot of IFR, without a lot of GPS. I've not had any problems. As for the offset idea, what is to prevent the other pilot from doing an offset that puts them directly in your path? Whatever happened to eyeballs and watching out for traffic? As for being difficult to fly the VOR, it was/is no more difficult than flying a compass heading and holding it.....which many pilots seem unable to do anymore. They would prefer that electronic gadgets do their flying for them and no thoughts as to what happens when the electrodes take a vacation. Ol Shy & Bashful - and unrepentant demanding grumpy old CFII |
![]() "SelwayKid" wrote in message om... "Icebound" wrote in message ... In the "good old" VOR days, it must have been pretty difficult to fly down the centerline of an airway (or of any direct track). ....snip... As for being difficult to fly the VOR, it was/is no more difficult than flying a compass heading and holding it.....which many pilots seem unable to do anymore. They would prefer that electronic gadgets do their flying for them and no thoughts as to what happens when the electrodes take a vacation. Never having flown a VOR course myself... I still doubt very much that any two pilots (OR auto-pilots), flying reciprocal headings between two VORs, would both be able to *simultaneously* hold a course to within 10 feet of the centre-line for the whole course, considering the receiver errors and that the VOR radial-signal *itself* probably varies more than that. I could be wrong. |
... [...] Never having flown a VOR course myself... I still doubt very much that any two pilots (OR auto-pilots), flying reciprocal headings between two VORs, would both be able to *simultaneously* hold a course to within 10 feet of the centre-line for the whole course, considering the receiver errors and that the VOR radial-signal *itself* probably varies more than that. I could be wrong. You are wrong. ![]() For two pilots to *intentionally* stay exactly on course center on a VOR airway would be challenging, granted. But the airway provides an "attractor" for airplanes, and inasmuch as the airplanes average toward the center of the airway, eventually a couple will come along flying the exact same distance from the actual airway (whether that's 0.0 miles off-center or 3.9 miles off-center). Like I said before, it's happened to me on several occasions (getting close enough to other aircraft on an airway to require evasive action, that is). That's with me handflying. Using an autopilot, VOR navigation can theoretically be VERY good, especially close to the station (within 10-20 miles). GPS increases the chances of collision, by reducing the average error. But the issue did already exist with VOR navigation. Keep in mind that GPS error is still going to be on the order 10 to 30 meters or so, just from the position information standpoint, and then on top of that you still have the problem of the airplane being kept exactly at the intended position (even with an autopilot, there's going to be some slop, and not all pilots are using autopilots in conjunction with their GPS navigation). The total error even in the GPS case can be much larger than the wingspan of typical GA aircraft, and so the same kinds of factors that protect against collisions when using VOR navigation also protect against collisions when using GPS navigation (though to a lesser degree). Pete |
Y'All,
This entire thread seems to be totally entranced with the possible conflict of aircraft on a heading/course. Whereas, the most likely conflict is in altitude between IFR and VFR supposedly flying with 500 feet of FAA separation. Some time ago I was told that ATC figures a + - error 300 feet. The altimeter is likewise allowed a 75 foot + - error. Not knowing for certain but assuming it is so. Look at the following senario. If we have an IFR and a VFR fllying in opposite hemisphereic directions in VFR conditions we have several possible extreme conditions. Take the first aircraft indicating 6000 feet west bound. The second aircraft indicating 5500 feet east bound. If both the transponders and altimeters have errors to the extreme in the opposite directions, they could still miss each other. If the first aircraft is flying 250 lower than indicated due to accumulated instrment error, while the other is actually flying 250 feet higher than indicated we have only see and be seen to save the situation. To me the probability of a midair is more likely to altitude error than heading error. The odds of having two such aircraft with hemispheric accumulative opposite errors in altitude sufficient to cause a midair is unlikely but more likely than an opposite heading midair. I believe this because the distances are matters of feet rather than miles. It takes both to actually cause the midair.so the total emphasis on course/heading is only a part of the equation. I haven't even mentioned GPS altitude as a factor. Mud wrestling anyone? Gene |
![]() "Gene Whitt" wrote in message link.net... Y'All, This entire thread seems to be totally entranced with the possible conflict of aircraft on a heading/course. Whereas, the most likely conflict is in altitude between IFR and VFR supposedly flying with 500 feet of FAA separation. ...snip... To me the probability of a midair is more likely to altitude error than heading error. The odds of having two such aircraft with hemispheric accumulative opposite errors in altitude sufficient to cause a midair is unlikely but more likely than an opposite heading midair. . Actually, if the two of them are not on the exact same location horizontally, the odds of a conflict because of altitude error is zero. While there is some remote possibility of being in the same location horizontally at the same time while crossing tracks, the potential to be in the same location horizontally is much greater when they are navigating reciprocal tracks between the same two waypoints. |
"Gene Whitt" wrote in message hlink.net...
Y'All, This entire thread seems to be totally entranced with the possible conflict of aircraft on a heading/course. Whereas, the most likely conflict is in altitude between IFR and VFR supposedly flying with 500 feet of FAA separation. Some time ago I was told that ATC figures a + - error 300 feet. The altimeter is likewise allowed a 75 foot + - error. Not knowing for certain but assuming it is so. Look at the following senario. If we have an IFR and a VFR fllying in opposite hemisphereic directions in VFR conditions we have several possible extreme conditions. Take the first aircraft indicating 6000 feet west bound. The second aircraft indicating 5500 feet east bound. If both the transponders and altimeters have errors to the extreme in the opposite directions, they could still miss each other. If the first aircraft is flying 250 lower than indicated due to accumulated instrment error, while the other is actually flying 250 feet higher than indicated we have only see and be seen to save the situation. To me the probability of a midair is more likely to altitude error than heading error. The odds of having two such aircraft with hemispheric accumulative opposite errors in altitude sufficient to cause a midair is unlikely but more likely than an opposite heading midair. I believe this because the distances are matters of feet rather than miles. It takes both to actually cause the midair.so the total emphasis on course/heading is only a part of the equation. I haven't even mentioned GPS altitude as a factor. Mud wrestling anyone? Gene Excellent point Gene. This is why maintaining a good visual scan is important, and why TCAS and TCAD systems are so valuable. I wish that we were at the point where every airplane equipped with a transponder also had a TCAS or TCAD system installed. It would be nice if this equipment were affordable enough to do this. Dean |
![]() "Peter Duniho" wrote in message ... "Icebound" wrote in message ... [...] Never having flown a VOR course myself... I still doubt very much that any two pilots (OR auto-pilots), flying reciprocal headings between two VORs, would both be able to *simultaneously* hold a course to within 10 feet of the centre-line for the whole course, considering the receiver errors and that the VOR radial-signal *itself* probably varies more than that. I could be wrong. You are wrong. ![]() For two pilots to *intentionally* stay exactly on course center on a VOR airway would be challenging, granted. But the airway provides an "attractor" for airplanes, and inasmuch as the airplanes average toward the center of the airway, eventually a couple will come along flying the exact same distance from the actual airway (whether that's 0.0 miles off-center or 3.9 miles off-center). Accepted and agreed. "eventually". But in the GPS case, it is pretty much in "every" case that two aircraft using those two waypoints will be pretty much in the center. |
... But in the GPS case, it is pretty much in "every" case that two aircraft using those two waypoints will be pretty much in the center. But "pretty much" still covers quite a bit of ground. There is only an increased risk of a collision, not a virtual certainty. |
![]() "Peter Duniho" wrote in message ... "Icebound" wrote in message ... But in the GPS case, it is pretty much in "every" case that two aircraft using those two waypoints will be pretty much in the center. But "pretty much" still covers quite a bit of ground. There is only an increased risk of a collision, not a virtual certainty. Oh, for sure. |
Peter Duniho ) wrote:
: GPS increases the chances of collision, by reducing the average error. But : the issue did already exist with VOR navigation. Keep in mind that GPS : error is still going to be on the order 10 to 30 meters or so, just from the : position information standpoint, and then on top of that you still have the : problem of the airplane being kept exactly at the intended position (even : with an autopilot, there's going to be some slop, and not all pilots are : using autopilots in conjunction with their GPS navigation). The GPS error you have quoted is relative to a fixed point on the ground. Most modern cheap GPS recievers in the same region looking at the same sats with differential corrections are within meters of each other and with good processing can produce a relative position within a few inches. The way to deal with this is to simply move the GPS course .1 nmi to the right. This means if your doing a 90 degree turn over a VOR using a GPS, you should make your turn .14 nmi away from the VOR and you should be able to see it out the left window. At this point it won't matter much considering the GA autopilot slop but things could change in the future and now is a good time to start putting these things in place. but there are more an more aircraft flying in the skys that don't but things could change in the future and now is a good time to start putting these things in place. -tim http://web.abnormal.com |
Can GPS be *too* accurate? Do I need some XTE?? | Icebound | Instrument Flight Rules | 82 | November 22nd 04 08:01 PM |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
How accurate was B-26 bombing? | ArtKramr | Military Aviation | 59 | March 3rd 04 10:10 PM |
Local TV News ran an accurate story about airframe icing last night | Peter R. | Piloting | 5 | January 29th 04 01:01 AM |
VOR and reverse sensing | Koopas Ly | Piloting | 40 | August 25th 03 01:26 AM |
