Can GPS be *too* accurate? Do I need some XTE??
Old November 18th 04, 11:00 PM
Blueskies
wrote in message ...
Blueskies wrote:
At midcourse, add a waypoint offset to one side or the other by a couple of miles. The enroute time would be changed
minimally...
But, that wouldn't be a parallel offset and would result in crossing the two end points precisely on course.
Also, the offset should be much smaller than 2 miles for domestic airspace operations.
But the end points are where you want to be - one is where you started and one is where you are going. If you have a
system that does not have the parallel course function, then this would be a simple solution. If you want perfect, then
plot a course using multiple waypoints...PIC chooses....
Can GPS be *too* accurate? Do I need some XTE?? Icebound Instrument Flight Rules 82 November 22nd 04 08:01 PM
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
How accurate was B-26 bombing? ArtKramr Military Aviation 59 March 3rd 04 10:10 PM
Local TV News ran an accurate story about airframe icing last night Peter R. Piloting 5 January 29th 04 01:01 AM
VOR and reverse sensing Koopas Ly Piloting 40 August 25th 03 01:26 AM
