I've seen "negative flaps" mentioned on spec sheets before.
A guess would be flaps extending upward and killing lift necessitated by the STOL nature of the aircraft. Am I even close? "Maule Driver" wrote in message m... Sometimes it's best to land without flaps. In my particular a/c, landings with *negative* flaps are advised. You don't want to go there. "Ramapriya" wrote in message om... Is it possible to land without using the flaps at all? Just a combination of the throttle (forward thrust too, perhaps?), elevator and ailerons... I know this will sound like a shocker but I'd appreciate a definitive NO, so that at least one doubt is bedded ![]() Ramapriya |
![]() Bill Denton wrote: I've seen "negative flaps" mentioned on spec sheets before. A guess would be flaps extending upward and killing lift necessitated by the STOL nature of the aircraft. Am I even close? Yes and no. Yes, the flaps extend upwards. No, it doesn't have anything to do with STOL. It's used to reduce drag and increase the cruise speed. I've found that it is counterproductive above a certain altitude (somewhere around 8,000'). When -7 results in a nose-high attitude, I go back to 0 degrees. I don't often get that high. As far as using them for landing is concerned, it allows the pilot to "three-point" the aircraft at a higher rate of speed. This gives you better directional control during crosswind landings. Note that the "three-point" landing under those circumstances is actually a two-point landing, but the points are the tailwheel and the upwind main. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
