#51
Reference: "Flight Theory for Pilots", Charles Dole, 4th ed.
stall -- airflow separation of the boundary layer from a lifting surface. characterized by a loss of life and an increase in drag. two types of stall of interest tot he non-jet pilot: slow speed and accelerated. |
#52
![]() "Blanche" wrote in message ... Reference: "Flight Theory for Pilots", Charles Dole, 4th ed. stall -- airflow separation of the boundary layer from a lifting surface. characterized by a loss of life and an increase in drag. two types of stall of interest tot he non-jet pilot: slow speed and accelerated. Proofread you work or you might scare hell out of somebody. |
#53
Thank you for your response. A lot of this has to do with semantics and
poorly defined terms on both sides...my comments are in the text: "Peter Duniho" wrote in message ... "Bill Denton" wrote in message ... You CAN'T take off without a stall, if an airfoil only has two states: flying or stalled. First of all, there is a continuous regime of "flight" between stalled and not stalled. It's not binary. But secondly, even if you assume the airfoil has just the two states, the rest of your conclusion regarding that is incorrect... You are both right and wrong on this one. Obviously, different parts of an aircraft stall at different speeds. This is why a stall in most light aircraft is generally benign: the stabilizer continues to fly long after the wing has stalled, resulting in the pitch-down generally required for stall recovery. So, as you approach the stall speed for an AIRCRAFT, differrent parts of the airplane will be stalled, or not flying; other parts will still be flying. Obviously, there is a range between the point where an element is producing zero lift, where it is producing enough lift to "fly" the unit itself at a consistent altitude, and where it is produing enough lift to fly the required load at a consistent altitude. Assume a perfect set of conditons, primarily containing an absolutely "level" portion of the earth, and consider the following scenarios. You take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level. You then close the throttle slightly, resulting in a slight descent. Even thought you are still flying straight and level, eventually you will impact the earth, even though the airplane as a whole (and probably all of it's component parts) are still "flying". You then take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level, but this time you completely close the throttle. In a short time, the wings will stop producing enough lift to keep the airplane in flight, it will pitch down and impact the earth, even though some of the airplane's component parts may still be flying. It is this second condition that most people consider to be a stall. But since my terminology may not be correct, it is obvious that I am neither an aeronautical engineer, a physisist, or as yet a pilot (none of which I claim to be), I think it is also evident that I do understand at least the basic principles involved in the discussion. If the airfoil is flying you cannot take off, and if it's not flying it's stalled. "If the airfoil is flying you cannot take off". Care to rephrase that? At best, I can assume you meant to write "if the airfoil is not flying you cannot take off". Which would be true (inasumuch as I might assume what you mean by "flying"), but not particularly germane. Your second clause, "if it's not flying it's stalled" seems to get to the heart of your misunderstanding however. This is a matter of the original poster's lack of precision, and my own desire to have a little fun. From the rest of the post, it is obvious that the poster is referring to a larger element than an airfoil, perhaps a wing or an entire airplane. Had I written the original post I would have used airplane. But please assume an airplane, accept my terminology, and consider the following: If a wheel is rolling, you cannot start it rolling. My statement was: " If the airfoil is flying you cannot take off, and if it's not flying it's stalled", which would translate as follows: "If the airplane IS flying it cannot START flying"' the rest reflects the flying/stalled paradyme, which I readly admit is not absolutely correct. "Flying" is not a technical aerodynamic term, and in particular you cannot say that "flying" is the opposite of "stalled". The opposite of "stalled" is "not stalled". As has already been pointed out, "stall" simply means that the airfoil's angle of attack is greater than the critical angle of attack. An airfoil that has no relative wind has NO angle of attack, and the term "stall" is meaningless in that context. Once the airfoil has relative wind (e.g. you start your takeoff roll), you can then look at the angle of attack and compare it to the critical angle of attack. Looking at the example of a takeoff roll, the wing's angle of attack remains below (and generally, WELL below) the critical angle of attack at all times. No stall at any point in time during the takeoff roll. Same thing applies to most landings. As the airplane slows after touching down, the amount of lift being generated is reduced, but this is compensated for by the wheels providing the balance of the required support. At no point does the wing wind up with a higher angle of attack than the critical angle of attack, and thus there is no stall. (There's a whole bunch of physics involved here that I don't yet know, so anyone, please feel free to correct whatever I get wrong.) We're trying. ![]() You stated: "It's flying as soon as you start moving on the runway". That is not correct. It IS correct. Well, inasmuch as you've failed to define "flying" for us, and inasmuch as "flying" has no predefined aerodynamic definition. The instant there is ANY relative wind, the wing is creating lift (since its angle of attack is below the critical AOA). That's my definition of "flying": "creating lift". What's your definition? Actually, it was the original poster who failed to define "flying" and specify what was flying. As noted above, I am looking at this in the context of an entire airplane, which seems to have been the original poster's intent. In fact, the airplane doesn't need to move on the runway at all; given a sufficient releative wind, parts of the airplane would begin to fly without the airplane moving forward at all. And given a relative wind even slightly higher than the stall speed of the aircraft, it could theoretically take off and continue to ascend with no forward movement. I agree with your definition, but it has to be consiered in light of whether we are discussing a single element or an entire airplane. It doesn't begin to fly until you develop enough relative wind to create enough lift to overcome drag. Lift overcomes gravity. Thrust overcomes drag. In order to lift off from the ground, you do need enough relative wind to allow the wing to generate enough lift to overcome the force of gravity. But if by "flying" you simply mean "to have lifted off from the ground", then it's especially true that "flying" is in no way the opposite of "stalled". You are correct on the lift/thrust thing; please understand that it's been 25 years since I read the Jepp private pilot manual ;-) If an airplane is only moving at 1 kt. down a runway, it is probably not flying. Again, you'll have to define "flying". But the wing certainly is developing lift, and certainly is NOT stalled. How 'bout if I throw in a 10 kt tailwind? g Forward motion of the aircraft is not required. Given a strong enough headwind, an airplane will readily fly backward; just ask some J3 drivers. Forward motion through the air mass IS required. Given a strong enough headwind, an airplane may well depart from the ground, but as soon as it's no longer tied to the ground, it will slow relative to the airmass and fall back to the ground. Probably in a stalled state, even. I proabably should have qualified that, but remember I'm not writing a textbook, I think all of us here frequently accept some unstated assumptions. And an aircraft will not land until it has reached a "stalled" state. Simply untrue. Virtually all of my landings involve touching down and coming to a stop without ever exceeding the wing's critical AOA. I hesitate to claim that I've *never* stalled the wing during a landing, but I sure don't do it intentionally. And this comes back to the flying/stalled paradym. BTW: I generally pick up a "nugget" or two from your posts, so your work is not in vain. I appreaciate it. Pete |
#54
![]() Bill Denton wrote: But if an airfoil has two states, stalled or flying, how can you land without a stall? It doesn't have just two states. It can be moving too slowly to be flying without being stalled. As has been posted several times, it is not stalled unless the airflow over the upper surface of the wing has separated from it. As has also been posted, that will not happen without an excessive angle of attack. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
#55
"Bill Denton" wrote
You take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level. You then close the throttle slightly, resulting in a slight descent. Even thought you are still flying straight and level, eventually you will impact the earth, even though the airplane as a whole (and probably all of it's component parts) are still "flying". No Bill..."straight and level" means maintaining heading and altitude You then take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level, but this time you completely close the throttle. In a short time, the wings will stop producing enough lift to keep the airplane in flight, it will pitch down and impact the earth, even though some of the airplane's component parts may still be flying. No Bill...in this case, the aircraft will pitch down to maintain the trimmed airspeed and the airplane WILL NOT stall. Yes, it will descend until it impacts the ground, but at no time will the aircraft stall. It is this second condition that most people consider to be a stall. No Bill...it is called a glide But since my terminology may not be correct, Boy...you hit that nail on the head it is obvious that I am neither an aeronautical engineer, a physisist, or as yet a pilot Yes Bill...that is absolutely obvious I think it is also evident that I do understand at least the basic principles involved in the discussion. No Bill... you do not. Bob Moore ATP B-707 B-727 L-188 Flight Instructor Airplanes and Instruments (since 1970) Naval Aviator S-2F P-2V P-3B !958-1967 PanAm (retired) |
#56
![]() Bill Denton wrote: You are both right and wrong on this one. Obviously, different parts of an aircraft stall at different speeds. This is why a stall in most light aircraft is generally benign: the stabilizer continues to fly long after the wing has stalled, resulting in the pitch-down generally required for stall recovery. You're correct that the stabilizer may stall at a different point than the wing, but the stabilizer on a traditional (ie. non-canard) aircraft pushes down on the tail, not up. If it stalls before the wing, the nose falls because there's nothing hold the tail down. If the wing stalls first, the nose falls because there's nothing holding the nose up. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
#57
... You are both right and wrong on this one. No. I am entirely right, not wrong at all. Obviously, different parts of an aircraft stall at different speeds. This is true, but completely irrelevant to my statement. [...] You then take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level, but this time you completely close the throttle. In a short time, the wings will stop producing enough lift to keep the airplane in flight, it will pitch down and impact the earth, even though some of the airplane's component parts may still be flying. First, your scenario is completely incorrect as to what would happen if you brought the throttle to idle. The airplane would NOT stall. It would simply pitch down enough to maintain the trimmed airspeed, and glide to whatever final destination it was aimed at. But more importantly, your understanding of a stall is flawed. Even simply looking at just the wing, and even ignoring such design features as washout, upon reaching the critical angle of attack lift does not go straight from maximum available lift to 0. There is a very narrow range of angle of attack where the lift drops off rapidly, and within this range, there is just as much lift as was available at angles of attack just below the critical angle of attack. For a variety of reasons, it's unlikely that a pilot would ever successfully negotiate this very narrow range. But it does exist, and a person who claims that a wing is strictly "not stalled" or "stalled" is simply demonstrated lack of completely knowledge of what happens during a stall. A stall is more like a dimmer light switch (with a very short throw) than it is like a regular "on/off" light switch. [...] I think it is also evident that I do understand at least the basic principles involved in the discussion. Very basic principles. But you still have quite a ways to go. You might do well to stop telling people they are wrong, at least until you've actually *mastered* the subject. But please assume an airplane, accept my terminology, and consider the following: If a wheel is rolling, you cannot start it rolling. My statement was: " If the airfoil is flying you cannot take off, and if it's not flying it's stalled", which would translate as follows: "If the airplane IS flying it cannot START flying"' the rest reflects the flying/stalled paradyme, which I readly admit is not absolutely correct. So you really did mean to write "if the airfoil is flying you cannot take off". I've got to say, that's got to be one of the most intentionally obtuse ways of saying something I've seen in a long time. In any case, you are simply incorrect to say "if it's not flying it's stalled". That is a patently false proposition. I have an airplane sitting in my hangar right now that is not flying (at least, it had better not be!), but it is not stalled either. Actually, it was the original poster who failed to define "flying" and specify what was flying. As noted above, I am looking at this in the context of an entire airplane, which seems to have been the original poster's intent. Another red herring. It really doesn't matter whether you are talking about the entire airplane or the wing. But for the record, when one refers to a "stall", they are generally referring to a stall of the main wing (and by implication, the entire airplane). In fact, the airplane doesn't need to move on the runway at all; given a sufficient releative wind, parts of the airplane would begin to fly without the airplane moving forward at all. I thought your claim was that an airplane that was flying (and thus presumably parts of an airplane that are flying) cannot take off. Now you are saying parts of the airplane can fly while still on the ground. Your statements are inconsistent with each other. And given a relative wind even slightly higher than the stall speed of the aircraft, it could theoretically take off and continue to ascend with no forward movement. No, it could not. With a strong enough wind, the airplane might lift off the ground, but it would immediately begin to slow within the airmass (accelerating backwards relative to the ground) and descend back to the ground. There would be no "continue to ascend" about it. I agree with your definition, but it has to be consiered in light of whether we are discussing a single element or an entire airplane. We are discussing the wing, which is the only thing of interest in this case. If you want to call that "the entire airplane", that's fine too, but make no mistake: it's still just the wing. If an airplane is only moving at 1 kt. down a runway, it is probably not flying. Again, you'll have to define "flying". But the wing certainly is developing lift, and certainly is NOT stalled. How 'bout if I throw in a 10 kt tailwind? g If you want to change the discussion in an attempt to make your comments make sense, feel free. I probably won't have the patience to bother though, and will simply feel justified in assuming that you aren't really interested in learning what the facts are. I recommend you stick with the original ideas, and where you've clearly meant "1 knot of relative wind" by saying "if an airplane is only moving at 1 knot down a runway", you should avoid complicating things by trying to reinterpret what you've written. Simply untrue. Virtually all of my landings involve touching down and coming to a stop without ever exceeding the wing's critical AOA. I hesitate to claim that I've *never* stalled the wing during a landing, but I sure don't do it intentionally. And this comes back to the flying/stalled paradym. The word is "paradigm". And frankly, I have no idea what you mean by "this comes back to". This thread *should* have stayed with the question of a stall all along. Only your digressions have prevented that. The bottom line here is that your statements that "you can't take off without a stall" and that "an aircraft will not land until it has reached a stalled state" are both patently false. You can very much both take off and land without ever stalling the airplane. Pete |
#58
Let's assume that I am completely wrong. Wouldn't we all have been better
served had you provided correct information as opposed to simply pointing out my error. I can't learn anything from that. Given your credentials, could you not have provided me, and many others, some useful information? "Bob Moore" wrote in message . 121... "Bill Denton" wrote You take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level. You then close the throttle slightly, resulting in a slight descent. Even thought you are still flying straight and level, eventually you will impact the earth, even though the airplane as a whole (and probably all of it's component parts) are still "flying". No Bill..."straight and level" means maintaining heading and altitude You then take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level, but this time you completely close the throttle. In a short time, the wings will stop producing enough lift to keep the airplane in flight, it will pitch down and impact the earth, even though some of the airplane's component parts may still be flying. No Bill...in this case, the aircraft will pitch down to maintain the trimmed airspeed and the airplane WILL NOT stall. Yes, it will descend until it impacts the ground, but at no time will the aircraft stall. It is this second condition that most people consider to be a stall. No Bill...it is called a glide But since my terminology may not be correct, Boy...you hit that nail on the head it is obvious that I am neither an aeronautical engineer, a physisist, or as yet a pilot Yes Bill...that is absolutely obvious I think it is also evident that I do understand at least the basic principles involved in the discussion. No Bill... you do not. Bob Moore ATP B-707 B-727 L-188 Flight Instructor Airplanes and Instruments (since 1970) Naval Aviator S-2F P-2V P-3B !958-1967 PanAm (retired) |
#59
On Fri, 19 Nov 2004 at 16:21:11 in message
, Bill Denton wrote: No, not a trick question... You CAN'T take off without a stall, if an airfoil only has two states: flying or stalled. If you admit you have only a limited knowledge why start off with a categorical statement? This indicates that you do not yet understand what an airfoil stall is. A stall occurs when the angle of attack of an airfoil exceeds a limit beyond which lift falls rather than increases. This angle would not normally ever be exceed in a take off. [1] If the airfoil is flying you cannot take off, and if it's not flying it's stalled. I suppose you mean above that if an aircraft is already flying it must have already taken off! Certain amount of truth in that but your second phrase is definitely wrong. See [1] (There's a whole bunch of physics involved here that I don't yet know, so anyone, please feel free to correct whatever I get wrong.) Fine but the purchase of an elementary book on aerodynamics would be a good start. You cannot expect a complete course on elementary aerodynamics by asking questions which to me, sound as if you are not really seeking elucidation. You stated: "It's flying as soon as you start moving on the runway". That is not correct. It doesn't begin to fly until you develop enough relative wind to create enough lift to overcome drag. If an airplane is only moving at 1 kt. down a runway, it is probably not flying. While 'it's flying as soon as you start moving on the runway' is not an ideal way of putting it the rest of your paragraph suggests that you do not yet understand the difference between lift and drag. Your third sentence is another categorical statement which is also wrong. Lift is a force generated at right angles to the airflow and drag is a force along the direction of the airflow. Since they act at right angles to each other lift is not a force that 'overcomes drag'. Your fourth sentence is correct when you talk about the whole aircraft but not if you are just talking about an airfoil.. And an aircraft will not land until it has reached a "stalled" state. Thus misconception of either or both of 'landing and stall' has already been dealt with in this thread. -- David CL Francis |
#60
Follow on...
My examples failed because I didn't properly think them through, and consequently did not account for pitch. Here is what I should have written, with my corrections in all caps... You take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level. You then close the throttle slightly, resulting in a slight descent. IF PITCH TRIM IS NOT CHANGED, eventually you will impact the earth, even though the airplane as a whole (and probably all of it's component parts) are still "flying". You then take an airplane to 1,000 ft AGL, and trim it so it is flying perfectly straight and level, but this time you completely close the throttle WHILE ATTEMPTING TO MAINTAIN THE ORIGINAL PITCH. In a short time, the wings will stop producing enough lift to keep the airplane in flight, it will pitch down and impact the earth, even though some of the airplane's component parts may still be flying. I believe these scenarios are correct, and I promise to do better next time! g |
All I Wanted For Christmas Were Inverted Spins | [email protected] | Aerobatics | 3 | December 29th 04 07:40 PM |
Spin Training | Captain Wubba | Piloting | 25 | April 12th 04 02:11 PM |
Cessna 150 Price Outlook | Charles Talleyrand | Owning | 80 | October 16th 03 02:18 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
