Peter Duniho ) wrote:
: GPS increases the chances of collision, by reducing the average error. But : the issue did already exist with VOR navigation. Keep in mind that GPS : error is still going to be on the order 10 to 30 meters or so, just from the : position information standpoint, and then on top of that you still have the : problem of the airplane being kept exactly at the intended position (even : with an autopilot, there's going to be some slop, and not all pilots are : using autopilots in conjunction with their GPS navigation). The GPS error you have quoted is relative to a fixed point on the ground. Most modern cheap GPS recievers in the same region looking at the same sats with differential corrections are within meters of each other and with good processing can produce a relative position within a few inches. The way to deal with this is to simply move the GPS course .1 nmi to the right. This means if your doing a 90 degree turn over a VOR using a GPS, you should make your turn .14 nmi away from the VOR and you should be able to see it out the left window. At this point it won't matter much considering the GA autopilot slop but things could change in the future and now is a good time to start putting these things in place. but there are more an more aircraft flying in the skys that don't but things could change in the future and now is a good time to start putting these things in place. -tim http://web.abnormal.com |
Can GPS be *too* accurate? Do I need some XTE?? | Icebound | Instrument Flight Rules | 82 | November 22nd 04 08:01 PM |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
How accurate was B-26 bombing? | ArtKramr | Military Aviation | 59 | March 3rd 04 10:10 PM |
Local TV News ran an accurate story about airframe icing last night | Peter R. | Piloting | 5 | January 29th 04 01:01 AM |
VOR and reverse sensing | Koopas Ly | Piloting | 40 | August 25th 03 01:26 AM |
