![]() Big John wrote: 4. If on an ILS, then altimeter setting would not be of prime importance. You ride the beam down until you see the R/W (or minimum altitude and go around) and land. The beam (needles) is/are the governing factor on az and el. But if the altimeter is not set correctly you don't know where the DH really is. ILS is sited to have a touch down point of say 2000 down R/W. Forget the exact figures. 1000. |
"Newps" wrote in message
... Big John wrote: 4. If on an ILS, then altimeter setting would not be of prime importance. You ride the beam down until you see the R/W (or minimum altitude and go around) and land. The beam (needles) is/are the governing factor on az and el. But if the altimeter is not set correctly you don't know where the DH really is. Are you really watching the altimeter 7 miles out when locked on the G/S? Pinky swear? There's some whacked lesson to be learned here. moo |
The GIII has a radio altimeter and GPWS. Either they had problems
being that far below the ILS or they were scud running and ignoring everything the aircraft was telling them. Guess the NTSB will let us know which. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Don Hammer wrote:
The GIII has a radio altimeter and GPWS. Either they had problems being that far below the ILS or they were scud running and ignoring everything the aircraft was telling them. Guess the NTSB will let us know which. Why would anyone scud run under a working ILS? Is there any advantage to that under any circumstance? - Andrew |
On Thu, 25 Nov 2004 21:45:29 -0500, Andrew Gideon
wrotD: Why would anyone scud run under a working ILS? Is there any advantage to that under any circumstance? - Andrew There is no advantage, but more than a few have dipped under the glideslope to take a peek for some stupid reason. Back in my FE days, I once nailed a captain in the back of the head with a clipboard after he ignored the FO's two dots low callout. Like I said before, the NTSB will probably shed some light on what happened here. Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
bush rules! | Be Kind | Military Aviation | 53 | February 14th 04 04:26 PM |
God Honest | Naval Aviation | 2 | July 24th 03 04:45 AM |
