"Stefan" wrote in message
... Happy Dog wrote: ALWAYS refuel after every flight, so that we always have full tanks. I don't know why more pilots don't do this. I don't know what you are flying, but with the planes I fly, full tanks aren't an option unless I want to fly alone. It should be obvious that I wasn't suggesting that anyone overload their aircraft. m |
Happy Dog wrote:
ALWAYS refuel after every flight, so that we always have full tanks. It should be obvious that I wasn't suggesting that anyone overload their aircraft. If you refuel after each flight to *full* tanks, as suggested, chances are you will be overload on the next flight unless you drain some fuel. Maybe not if you're the only pilot who flyes the plane and you have a certain loading pattern, but certainly in a club (or FBO) environment. In our club, we *forbid* people to fill the tanks after a flight to more than two thirds. (I know it wasn't you who suggested it, but you confirmed the suggestion.) Stefan |
you will be overload on the next flight unless you drain some fuel. Maybe not if you're the only pilot who flyes the plane and you have a certain loading pattern, but certainly in a club (or FBO) environment. Your club needs to get a Pathfinder or Dakota. Full tanks (84 gallons), four 200 pound guys, plus luggage -- no problemo! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() "Happy Dog" wrote: ALWAYS refuel after every flight, so that we always have full tanks. I don't know why more pilots don't do this. I don't know what you are flying, but with the planes I fly, full tanks aren't an option unless I want to fly alone. It should be obvious that I wasn't suggesting that anyone overload their aircraft. No, but you were wondering why more pilots don't "ALWAYS refuel after every flight, so that [they] always have full tanks," which is a silly practice unless one ALWAYS knows the next flight will require full tanks. At my old club, members were asked NOT to fill the tanks after using the airplanes, so that the next pilot could add fuel appropriate to his flight. -- Dan C172RG at BFM |
On Sun, 5 Dec 2004 06:42:51 -0600, "Dan Luke"
wrote in :: ... so that [they] always have full tanks," which is a silly practice unless one ALWAYS knows the next flight will require full tanks. The practice of topping the fuel tanks after each flight rests on the notion that air contains a certain amount of moisture, and that the water will condense out of the air contained in partially emptied tanks and contaminate the aircraft's fuel system. |
![]() "Larry Dighera" wrote in message ... On Sun, 5 Dec 2004 06:42:51 -0600, "Dan Luke" wrote in :: ... so that [they] always have full tanks," which is a silly practice unless one ALWAYS knows the next flight will require full tanks. The practice of topping the fuel tanks after each flight rests on the notion that air contains a certain amount of moisture, and that the water will condense out of the air contained in partially emptied tanks and contaminate the aircraft's fuel system. Which is an old wives tale. The amount of water contained in 20-30 gallons of air is insignificant. -- Dan C172RG at BFM |
On Sun, 5 Dec 2004 07:40:00 -0600, "Dan Luke"
wrote in :: "Larry Dighera" wrote in message .. . On Sun, 5 Dec 2004 06:42:51 -0600, "Dan Luke" wrote in :: ... so that [they] always have full tanks," which is a silly practice unless one ALWAYS knows the next flight will require full tanks. The practice of topping the fuel tanks after each flight rests on the notion that air contains a certain amount of moisture, and that the water will condense out of the air contained in partially emptied tanks and contaminate the aircraft's fuel system. Which is an old wives tale. The amount of water contained in 20-30 gallons of air is insignificant. A Piper PA28-235 can have 84 gallons of fuel in 4 tanks, so leaving them half empty, for instance in a humid maritime environment, overnight where the temperature drops sufficiently to cause the moisture to condense out of the 40 gallons of air contained in them, will result in enough water in the fuel system to interfere with operation of the aircraft's power plant. However, PA28-235 can carry its empty weight (~1,400 lbs) in useful load, so weight management through fuel offloading is seldom necessary. Personally, I prefer that water never be present in the aircraft fuel system, especially in aircraft with fuel tank bladders.... |
Larry Dighera wrote:
A Piper PA28-235 can have 84 gallons of fuel in 4 tanks, so leaving them half empty, for instance in a humid maritime environment, overnight where the temperature drops sufficiently to cause the moisture to condense out of the 40 gallons of air contained in them, will result in enough water in the fuel system to interfere with operation of the aircraft's power plant. At 40 degrees Celsius, 1 cubic meter of saturated air contains roughly 40 grams of water. (I leave it to you to convert this to US units.) Hardly significant. Stefan |
![]() A Piper PA28-235 can have 84 gallons of fuel in 4 tanks, so leaving them half empty, for instance in a humid maritime environment, overnight where the temperature drops sufficiently to cause the moisture to condense out of the 40 gallons of air contained in them, will result in enough water in the fuel system to interfere with operation of the aircraft's power plant. At 40 degrees Celsius, 1 cubic meter of saturated air contains roughly 40 grams That's about one and a third ounces. Remember, if all of the water comes out of the air, it settles to the bottom, and is either drained or used by the engine. It would take a lot of such cycles before enough water would be in the tank to matter. As someone else already said, full tanks to prevent dangerous condensation is another aviation myth. |
On Sun, 05 Dec 2004 15:29:44 +0100, Stefan
wrote in :: Larry Dighera wrote: A Piper PA28-235 can have 84 gallons of fuel in 4 tanks, so leaving them half empty, for instance in a humid maritime environment, overnight where the temperature drops sufficiently to cause the moisture to condense out of the 40 gallons of air contained in them, will result in enough water in the fuel system to interfere with operation of the aircraft's power plant. At 40 degrees Celsius, 1 cubic meter of saturated air contains roughly 40 grams of water. (I leave it to you to convert this to US units.) Hardly significant. While the amount of water in the fuel system may be small, so is the diameter of the fuel lines. In the cool environs at altitude, what is to prevent the water from forming a frozen 'cork' blocking fuel flow? Aircraft with fuel bladders that have become deformed or otherwise lack a smooth bottom surface are capable of trapping significant amounts of water and preventing it from reaching the fuel sumps for removal without tipping the wings and other effort. The later model Cessna 172s now have 10 wing drains as a result. I submit, that water in an aircraft fuel system has the potential for disaster. To argue otherwise seems absurd. |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Baghdad airport safe to fly ?? | Nemo l'ancien | Military Aviation | 17 | April 9th 04 11:58 PM |
An Algorithm for Defeating CAPS, or how the TSA will make us less safe | Aviv Hod | Piloting | 0 | January 14th 04 01:55 PM |
Fast Safe Plane | Charles Talleyrand | Piloting | 6 | December 30th 03 10:23 PM |
Four Nimitz Aviators Safe after | Otis Willie | Naval Aviation | 0 | July 28th 03 10:31 PM |
