#191
![]() "Dan Luke" wrote in message ... "Happy Dog" wrote: ALWAYS refuel after every flight, so that we always have full tanks. I don't know why more pilots don't do this. I don't know what you are flying, but with the planes I fly, full tanks aren't an option unless I want to fly alone. It should be obvious that I wasn't suggesting that anyone overload their aircraft. No, but you were wondering why more pilots don't "ALWAYS refuel after every flight, so that [they] always have full tanks," which is a silly practice unless one ALWAYS knows the next flight will require full tanks. At my old club, members were asked NOT to fill the tanks after using the airplanes, so that the next pilot could add fuel appropriate to his flight. To be specific, my concern is that I see many pilots who don't carry more fuel when they could and within reason. OK? le moo |
#192
![]() "Frank Ch. Eigler" wrote: Not much, but if it decides to freeze and get sucked in and collected, could it plug up a fuel line? No. Fuel lines have a strainer around them inside the tank. The iceball would hang on the strainer and would not be big enough to block very much of it. George Patterson The desire for safety stands against every great and noble enterprise. |
#193
![]() Larry Dighera wrote: While the amount of water in the fuel system may be small, so is the diameter of the fuel lines. In the cool environs at altitude, what is to prevent the water from forming a frozen 'cork' blocking fuel flow? The fuel strainer inside the tank. George Patterson The desire for safety stands against every great and noble enterprise. |
#194
![]() Larry Dighera wrote: While the engine may be able to continue running after ingesting some water, with an ambient temperature low enough, it wouldn't get fuel if water in the fuel lines froze. What volume of water is enough to cause such a frozen plug? This is just about impossible in the air. Moving water stays liquid at a much lower temperature than standing water. You are postulating a situation in which the water in the gas tank is above freezing and the temperature in the fuel lines is about 0 degrees Fahrenheit. Of course, it's possible for water to get into the lines on the ground and freeze when the temperature gets below freezing, but then the aircraft would never start. George Patterson The desire for safety stands against every great and noble enterprise. |
#195
![]() "Happy Dog" wrote: To be specific, my concern is that I see many pilots who don't carry more fuel when they could and within reason. OK? Now that the goalposts are in a new location, I declare that you have scored a touchdown. |
#196
"G.R. Patterson III" wrote in message
... This is just about impossible in the air. Moving water stays liquid at a much lower temperature than standing water. You are postulating a situation in which the water in the gas tank is above freezing and the temperature in the fuel lines is about 0 degrees Fahrenheit. Of course, it's possible for water to get into the lines on the ground and freeze when the temperature gets below freezing, but then the aircraft would never start. Actually, ice in the fuel can freeze in the tanks, forming crystals small enough to pass into the fuel lines, and then form an aggregate large enough to restrict (or even block entirely) that fuel line. An alternative possibility is that the water may freeze in a larger form in the tank, but not block the fuel intake port from the fuel tank until something during flight jostles it enough to block the port. Of course, there is always the standard issue of liquid water in the fuel tank, possibly shifting and/or coalescing enough during flight to create a problem just after takeoff or well into the flight. IMHO, the only real question is how much water you might accumulate due to condensation. That water in the tanks can cause a problem, whether due to freezing or otherwise, is simply not a question. It can. As I've said in a different post, I agree that the chances of condensate accumulating in large enough quantity to cause a real problem is extremely low. But I don't think it's reasonable to claim that it could never happen. Pete |
#197
... "Happy Dog" wrote: To be specific, my concern is that I see many pilots who don't carry more fuel when they could and within reason. OK? Now that the goalposts are in a new location, I declare that you have scored a touchdown. How so? It's irritating to have comments nitpicked by the dedicatedly pugnacious. Why didn't anyone go after the original poster and accuse him of overloading his plane? After all, he said he *always* tops up. That obvious things have to be made boringly clear is, well, Usenet. le moo |
#198
Peter,
My understanding is that having the rubber "wetted" by the fuel helps extend their lifetime. "Ah, but my fuel bladders will look pristine to the NTSB guys" , said the pilot as he crashed into the trees at the end of the runway. -- Thomas Borchert (EDDH) |
#199
![]() "Dan Luke" writes: Remember that in Larry's example the water is distributed among four tanks. 2mL split four ways ain't enough to worry about. Perhaps (though others' tanks are much bigger). But as to how such freezing could happen, consider (not) topping off on such a warm day, and climbing to 10000 ft for cruise. That temperature drop might be all you need to freeze out the water. It's not only during winter that this may be a consideration. Can someone imagine a scenario where over several heat/cool fill/fly cycles such ice could accumulate? Perhaps failing to sample the fuel bowl/drains over several consecutive flights? If it freezes will it float in avgas or stay on the bottom? The density of avgas is around 0.7 g/mL, water 1.0 g/mL, ice 0.9 g/mL. Ice would still drop to the bottom. - FChE |
#200
You are (statistically speaking) more likely to get stuck by lightning,
and win the lottery than get injured in a small plane crash. The only reason you hear about plane crashes on the news is that they happen so rarely that each time it is considered newsworthy. Imagine if there were a front page news report everytime there was an auto crash... June wrote: I need some information from people 'in the field'. My husband has his private license and is just starting to work on his IFR for recreational flying. He wants to buy into a plane partnership, saying he will be saving money rather than renting. We have 2 little girls. I worry for his safety as it seems there is another small plane crash every other time you turn on the news. I think he should focus on this hobby when the kids are older, not when he has such a young family. Your opinions would be appreciated. |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Baghdad airport safe to fly ?? | Nemo l'ancien | Military Aviation | 17 | April 9th 04 11:58 PM |
An Algorithm for Defeating CAPS, or how the TSA will make us less safe | Aviv Hod | Piloting | 0 | January 14th 04 01:55 PM |
Fast Safe Plane | Charles Talleyrand | Piloting | 6 | December 30th 03 10:23 PM |
Four Nimitz Aviators Safe after | Otis Willie | Naval Aviation | 0 | July 28th 03 10:31 PM |
