"Ernest Christley" wrote in message
. com... Don't the federal regulation forbid dropping under 500ft AGL over someone else's property? Not even close. I think the law is that anything below 500 is the airspace of the private property owner Property owners have no right of ownership of any sort with respect to the airspace above their property. |
else's property? Not even close. The regs generally forbid flying an airplane less than 500 feet from any structure or vessel, except for takeoff and landing. Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
"Jose" wrote in message
m... The regs generally forbid flying an airplane less than 500 feet from any structure or vessel, except for takeoff and landing. So what? Those regulations don't apply in congested areas (such as those described by Ernest), and they don't apply during takeoffs and landings in any case (the specific situation this entire thread is about). |
structure or vessel, except for takeoff and landing. So what? Those regulations don't apply in congested areas (such as those described by Ernest), and they don't apply during takeoffs and landings in any case (the specific situation this entire thread is about). Over congested areas it's 1000 feet. And I stated "except for takeoff and landing", which =is= what the thread is about. I was clarifying what the reg is, not arguing that the reg prohibits takeoff or landing outside an airport. Jose (r.a.homebuilt trimmed) -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
"Peter Duniho" wrote:
I think the law is that anything below 500 is the airspace of the private property owner Property owners have no right of ownership of any sort with respect to the airspace above their property. Yes they do. A property owner has rights to airspace for any reasonable use thereof under common law, where FAA's 500' reference may be irrelevant. One example is erection of an antenna tower on your property. FAA rules under Part 77 on obstructions apply only to a potential obstruction to public-use airports and to otherwise navigational airspace -- at least 500' for the latter, but not to private strips at all. So if such a tower under 500' AGL poses a hazard to aircraft for an adjoining private airfield, the rights of the antenna owner's property may just be superior under common law. Of course, to be decided in a court of common pleas, or by Judge Judy, or at minimum a rather good "arguendo" exercise under individual State law as to "neighbor law" in a law school class! Fred F. |
"TaxSrv" wrote in message
... Yes they do. No, they don't. [...] So if such a tower under 500' AGL poses a hazard to aircraft for an adjoining private airfield, the rights of the antenna owner's property may just be superior under common law. That in no way alters the right of any aircraft to pass through that airspace freely. The property owner does not "own" the airspace, and has no privilege to prohibit other people from using it where it is not already being occupied by something else, as suggested by the person to whom I was replying. Pete |
[...] So if such a tower under 500' AGL poses a hazard to aircraft for an adjoining private airfield, the rights of the antenna owner's property may just be superior under common law. That in no way alters the right of any aircraft to pass through that airspace freely. The property owner does not "own" the airspace, and has no privilege to prohibit other people from using it where it is not already being occupied by something else, as suggested by the person to whom I was replying. It's not really a matter of "ownership," but rather whether use of airspace down low over other people's property denies them their right of enjoyment and freedom from hazards. Here's 3 samples of decisions in various states, concerning private airstrips: "The court emphasized that in this case the airport was private, not public, and ruled that "there is nothing to distinguish a private airport from any other private business with regard to enjoining operations which create a nuisance." "The trial court issued an injunction against use of the airstrip, and the appellate court held the injunction appropriate on the grounds that use of the airstrip, even without actual invasion of the utility's land, constituted a nuisance to the utility's transmission lines." [Note the utility put up the transmission lines; then sued the adjacent private airport owner!] "Neighboring property owners sued owners of a private airport for damages due to aircraft noise. Held: An airport operating in conformance with state and federal law may nevertheless constitute a nuisance, and the Federal Aviation Act does not preempt damages for unreasonable noise from an airport....In addition, plaintiffs may recover for inconvenience, annoyance, and discomfort caused by nuisance as long as the interference with use and enjoyment of their property is unreasonable and substantial." Fred F. |
![]() TaxSrv wrote: "The trial court issued an injunction against use of the airstrip, and the appellate court held the injunction appropriate on the grounds that use of the airstrip, even without actual invasion of the utility's land, constituted a nuisance to the utility's transmission lines." [Note the utility put up the transmission lines; then sued the adjacent private airport owner!] This is odd as most utilities will bury the lines for your runway if you pay the cost of burial. Unless of course you're talking about those monster transmission lines. |
... It's not really a matter of "ownership," That's what I've been saying. Thank you. |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Juan Jiminez is a liar and a fraud (was: Zoom fables on ANN | ChuckSlusarczyk | Home Built | 105 | October 8th 04 12:38 AM |
Bush's guard record | JDKAHN | Home Built | 13 | October 3rd 04 09:38 PM |
Bu$h Jr's Iran-Contra -- The Pentagone's Reign of Terror | PirateJohn | Military Aviation | 1 | September 6th 03 10:05 AM |
