![]() "Jose" wrote in message m... Jay, as has been pointed out here before, class D controllers do not control air traffic. The FARs say that class D is controlled airspace. They also say that you have to obey ATC instructions. What are the tower controllers controlling there if not air traffic? Ground controllers control ground traffic. They are sometimes the same person as the tower controller, sometimes they are not. Class D towers do a lot more than sequencing. They can also keep you out of their airspace, issue instructions to aircraft within their airspace and expect to be obeyed (or know the reason why not) and so forth. They will also issue advisories of other traffic and they will control the traffic pattern. |
have to obey ATC instructions. What are the tower controllers controlling there if not air traffic? They are not controlling air traffic in the sense of taking responsibility for separation (which they do in IFR for example, and perhaps in positive control areas - a controller will certainly jump in and clarify) That they can keep you out is true, but not relevant to my point (of it being primarily a pilot's responsibility to see and avoid) Jose -- Freedom. It seemed like a good idea at the time. for Email, make the obvious change in the address. |
![]() "Jose" wrote in message news ![]() The FARs say that class D is controlled airspace. They also say that you have to obey ATC instructions. What are the tower controllers controlling there if not air traffic? They are not controlling air traffic in the sense of taking responsibility for separation (which they do in IFR for example, and perhaps in positive control areas - a controller will certainly jump in and clarify) I want to put to rest once and for all the idea that class D controllers do not control air traffic, however. They do. They issue vectors, departure and arrival instructions for both VFR and IFR traffic, and routing instructions through their airspace for both VFR and IFR traffic. They also make an attempt to maintain separation and controllers who fail that responsibility have been found at least partially at fault in NTSB reports. I agree with you that separation is primarily the pilot's responsibility, but this is not a peculiarity of class D. It is true no matter what airspace you are in. |
do not control air traffic, however. They do. They issue vectors, departure and arrival instructions for both VFR and IFR traffic, and routing instructions through their airspace for both VFR and IFR traffic. They also make an attempt to maintain separation and controllers who fail that responsibility have been found at least partially at fault in NTSB reports. I agree with you that separation is primarily the pilot's responsibility, but this is not a peculiarity of class D. It is true no matter what airspace you are in. Last I remember, a CLASS D tower is a VFR tower.. they can only handle 1 IFR aircraft at a time, and then it is on a relayed clearance from an IFR facility, they cannot issue or change an IFR clearance without permission from the IFR controlling facility. A VFR tower cannot issue a "radar vector", they can provide recommended headings to fly. But then again, it's been more than a few years since I was on the other side of the headset, sitting at the radar scope. BT |
![]() "BTIZ" wrote in message news:Q1vwd.31798$Ae.18996@fed1read05... Last I remember, a CLASS D tower is a VFR tower.. Not necessarily. they can only handle 1 IFR aircraft at a time, and then it is on a relayed clearance from an IFR facility, they cannot issue or change an IFR clearance without permission from the IFR controlling facility. That's all true for VFR towers except for the part about handling only one IFR aircraft at a time. But then again, it's been more than a few years since I was on the other side of the headset, sitting at the radar scope. Apparently. |
![]() But then again, it's been more than a few years since I was on the other side of the headset, sitting at the radar scope. Apparently. *Was that necessary?* |
![]() "BTIZ" wrote in message news:Q1vwd.31798$Ae.18996@fed1read05... A VFR tower cannot issue a "radar vector", they can provide recommended headings to fly. I said "vector" and "departure instructions," not "radar vector." If the tower tells you to depart on left downwind it is not a "recommendation," it is an ATC instruction that you are obligated to follow under 91.123(b). Some class D towers have upgraded radar and they do issue radar vectors, by the way. |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
Negative XPDR - under the outer ring of Class C | bcjames | Piloting | 8 | August 30th 04 11:49 PM |
Must the PLANE be IFR-equipped to fly over17,500? | john smith | Home Built | 11 | August 27th 04 02:29 AM |
Overlapping class C & D | Andrew Sarangan | Piloting | 14 | May 6th 04 04:08 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
