Mooney Engine Problems in Flight
Old December 16th 04, 11:07 PM
Newps
Paul Smedshammer wrote:
In article , Newps wrote:
a 600 foot overcast with tops at 1,500 feet. Clear above 1,500 feet with
visibility well over 10 miles … more like 50 miles. Correct me if I'm wrong
but a VFR pilot can fly at 4,500 feet in this situation. It might not be
smart but it is legal. Let me know if I'm wrong.
It's legal, goddamned stupid, but legal.
How is it any more stupid than say flying at night?
I didn't make the comparison.
  #44
Old December 17th 04, 06:07 PM
Paul Smedshammer
In article .com, "Robert M. Gary" wrote:
Good choice. Lasar will do an excellent job, they have a great
reputation in the Mooney community.
Yes, technically, VFR-on-Top has its own FAA meaning that is neither
VFR or necessarily "top top". A controller issuing a clearance
"VFR-on-top" is issuing a type of IFR clearance. However, we all knew
what you meant. BTW: I fly out of Sacramento, are in near here?
-Robert, CFI
Based out of Petaluma. Heading up to Lasar today to see if they can find
anything wrong. Thanks again everybody for all the information. I will post
what is found or isn't found.
Paul
  #45
Old December 18th 04, 04:49 AM
Paul Smedshammer
-Robert, CFI
Paul
I just spent 4 hours of mechanic time up at Lasar. At my request they went
through everything. Checked the tanks for water, checked the gas collator,
servo, injectors, spark plugs, exhaust for blockage, air intakes (filter,
alternate air, ram air) all without finding anything. Test flight afterward
and the flight home both had the engine running perfectly as if nothing had
ever happened. Everybody is scratching their heads a little but I'm pretty
sure the culprit was water in the tank. On the flight that I had the trouble,
I made a step bank turn to stay under the fog ahead and I'm thinking there was
some water trapped behind a rib in the wing. The steep turn could have
stirred it up and had it settle to the bottom of the tank, which then got
pulled into the engine. It ran really rough for a while as it was a mixture
(recently stirred up) of water and fuel and then when that mixture was all
pushed through, it cleared up and ran normal. Leaving no sign of what had
happened.
Lessons learned, 1) do not fly VFR Over the Top unless you absolutely have to
and if you do get a lot of altitude so you might have a chance to glide to a
clear area to land and 2) really work the wings and sump the tanks vigorously
after rain or even dense fog - or for that matter anytime before you go flying
- you might have trapped water in the wing somewhere.
Thanks again to everybody who responded. I have learned a lot through this
experience.
Paul
Mooney M20F
  #46
Old December 18th 04, 09:40 AM
AJW
trouble,
was
happened.
flying
experience.
Paul
Mooney M20F
Paul, you may want to think about that "steep bank to avoid fog ahead" comment.
It suggests
1: you may have been low,
2: if it stirred up the fuel tanks it may have been uncoordinated.
Man, if there's a nit to be picked. . .
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Piloting 0 September 22nd 04 07:13 PM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 05:12 AM
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
Sim time loggable? [email protected] Instrument Flight Rules 12 December 6th 03 07:47 AM
