But how much is a reliable switch worth when you're truckin' through a Class
B and all hell breaks lose? In addition to the built-in PTT switch on the 172 I rent (with my Dave Clark headset), the plane has a standard hand-held mike installed. I also carry my own hand-held mike in the bottom of my headset bag, giving me 3 mikes. Talk about 'belt and suspenders'.... :-) |
A built-in PTT was one reason I chose my particular headset. It has a PTT
built into one of the earcups. If the aircraft's, or any add-on PTT goes TU, I can plug my headset into the jacks directly and use my last-ditch PTT. -- Scott |
Remote Switch for Pointer ELT --- Why Does It Need Voltage? | jls | Home Built | 1 | November 22nd 04 09:13 PM |
C-172 landing light switch | JFLEISC | Piloting | 16 | May 6th 04 01:15 AM |
C-172 landing light switch | JFLEISC | Owning | 10 | May 5th 04 11:05 PM |
Portable Push-To-Talk switch help | Eric Brown | Owning | 9 | April 16th 04 04:26 AM |
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? | jls | Owning | 3 | April 11th 04 04:55 PM |
