Sectional Usage Poll
Old December 22nd 04, 05:33 AM
Art Varrassi
Sectional - North Up
Garmin GPSMAP 196 - North Up
Art Varrassi
PP-ASEL
"Daniel L. Lieberman" wrote in message
I have been advised that some people when using a sectional always hold it
with North up even when they are flying South rather than orienting it
along
their flight path. This is an option on moving map GPS systems.
Do you a) keep North up or b) orient the map in the direction in which you
are flying?
TIA
  #42
Old December 22nd 04, 12:47 PM
Denny
North up, definitely... There is nothing wrong with drawing lines on
the chart... I have charts that have all kinds of colored lines on
them... While I now use GPS as my primary nav tool, I always keep a
chart open and the #1 VOR tracking my progress so that when the
inevitable GPS meltdown occurs (inside or outside of the cockpit) I
will simply keep on truckin'...
Denny
  #43
Old December 22nd 04, 01:51 PM
Dan Luke
"Daniel L. Lieberman" wrote:
North up, charts & GPS moving map.
I find GPS map re-draws disorienting if I use track up. Also, geographical
shapes look unfamiliar if they're not depicted north up.
Dan
C-172RG at BFM
  #44
Old December 22nd 04, 02:02 PM
Travis Marlatte
For sectionals and paper maps, it's north up but it's because of the labels.
When I use an electronic chart (or a nav system in a car), I use heading up.
Travis
along their flight path. This is an option on moving map GPS systems.
are flying?
TIA
  #45
Old December 23rd 04, 01:35 AM
Andrew Sarangan
I tend to use North-Up when I am flying using other means (GPS, VOR ),
while using the sectional only for monitoring progress. I use heading-up
when I am actively looking at the section for navigation.
"RobsSanta" wrote in
news:0i%xd.69968$DC.32060@fed1read03:
Oriented to flight path... my old instructor always said that was the
way he did it during their bombing runs over Germany in the 1940's
Rob
hold it with North up even when they are flying South rather than
orienting it
along
which you are flying?
TIA
  #46
Old December 24th 04, 03:35 PM
Greg Faris
I like North Up also. I do not have difficulty visualizing orientation when
flying in a direction different from the map's orientation. I have had
instructors try to convert me - and in some cases they made good points
about how my expectations would be better met with the "orientated map"
method. Once I flew to a small airfield with my usual, North Up method. I
had no difficulty getting there, but I was surprised for about a half a
second by the orientation of the runway. The instructor used this as proof
that I would have flown it better with the map turned.
"Travis Marlatte" wrote in message
k.net...
labels.
up.
Travis
it
you
are flying?
TIA
WAC vs Sectional [email protected] Instrument Flight Rules 60 February 8th 05 12:22 AM
WAC vs Sectional [email protected] General Aviation 12 February 2nd 05 03:03 PM
AVIATIONTOOLBOX: how I convert sectional maps to map chunks Kyler Laird General Aviation 2 December 4th 03 01:09 AM
Old New York Sectional PaulaJay1 Owning 2 November 25th 03 03:27 AM
