I know that a car's engine needs to be mated to the transmission for
propulsion. This I know isn't the case with an aircraft with a jet engine; if the engine is turned on without the brakes applied, the jet of air leaving the engine will hurl the craft forward. My doubt is, why does this forward motion effect not occur during push-back, when the engines are normally turned on? Is it because at low revs the engine would lack the punch to initiate the forward motion of a heavy aircraft? If not, I'd imagine the push-back becomes a bit of a tiresome affair by the time it's over... Sorry if this is infuriatingly elementary, but I need to ask somewhere ![]() Ramapriya |
There is not enough thrust at idle to be a problem.
Mike MU-2 "Ramapriya" wrote in message oups.com... I know that a car's engine needs to be mated to the transmission for propulsion. This I know isn't the case with an aircraft with a jet engine; if the engine is turned on without the brakes applied, the jet of air leaving the engine will hurl the craft forward. My doubt is, why does this forward motion effect not occur during push-back, when the engines are normally turned on? Is it because at low revs the engine would lack the punch to initiate the forward motion of a heavy aircraft? If not, I'd imagine the push-back becomes a bit of a tiresome affair by the time it's over... Sorry if this is infuriatingly elementary, but I need to ask somewhere ![]() Ramapriya |
In article . net,
"Mike Rapoport" wrote: There is not enough thrust at idle to be a problem. Mike MU-2 "Ramapriya" wrote in message roups.com... I know that a car's engine needs to be mated to the transmission for propulsion. This I know isn't the case with an aircraft with a jet engine; if the engine is turned on without the brakes applied, the jet of air leaving the engine will hurl the craft forward. My doubt is, why does this forward motion effect not occur during push-back, when the engines are normally turned on? Is it because at low revs the engine would lack the punch to initiate the forward motion of a heavy aircraft? If not, I'd imagine the push-back becomes a bit of a tiresome affair by the time it's over... Sorry if this is infuriatingly elementary, but I need to ask somewhere ![]() Ramapriya I've seen numerous times on an icy ramp when it was. -- Ron Parsons |
![]() "Ramapriya" wrote in message oups.com... I know that a car's engine needs to be mated to the transmission for propulsion. This I know isn't the case with an aircraft with a jet engine; if the engine is turned on without the brakes applied, the jet of air leaving the engine will hurl the craft forward. My doubt is, why does this forward motion effect not occur during push-back, when the engines are normally turned on? Is it because at low revs the engine would lack the punch to initiate the forward motion of a heavy aircraft? If not, I'd imagine the push-back becomes a bit of a tiresome affair by the time it's over... Sorry if this is infuriatingly elementary, but I need to ask somewhere ![]() Ramapriya At idle, turbo fan engines, or turbo jet engines do not make a tremendous amount of thrust. The push-back tugs are very powerful, with very low gearing. They simply push harder than the engines are pushing. Sometimes, the engines are not started until after push-back, or while the push-back is taking place. Some of the heavy metal pilots can tell you better than me, but it is my understanding that it takes well over 50% RPM to get 50% thrust, so it goes to follow that 10% RPM is way less than 10% thrust. Where have you been? Kinda' lonely around here, without your constant questions! g -- Jim in NC |
"Morgans" wrote: "Ramapriya" wrote in message roups.com... I know that a car's engine needs to be mated to the transmission for propulsion. This I know isn't the case with an aircraft with a jet engine; if the engine is turned on without the brakes applied, the jet of air leaving the engine will hurl the craft forward. My doubt is, why does this forward motion effect not occur during push-back, when the engines are normally turned on? Is it because at low revs the engine would lack the punch to initiate the forward motion of a heavy aircraft? If not, I'd imagine the push-back becomes a bit of a tiresome affair by the time it's over... Sorry if this is infuriatingly elementary, but I need to ask somewhere ![]() Ramapriya At idle, turbo fan engines, or turbo jet engines do not make a tremendous amount of thrust. The push-back tugs are very powerful, with very low gearing. They simply push harder than the engines are pushing. Sometimes, the engines are not started until after push-back, or while the push-back is taking place. Some of the heavy metal pilots can tell you better than me, but it is my understanding that it takes well over 50% RPM to get 50% thrust, so it goes to follow that 10% RPM is way less than 10% thrust. Where have you been? Kinda' lonely around here, without your constant questions! g Thrust and RPM do not have a linear relationship. Idle can be as high as 60%. -- Ron Parsons |
Hi there Jim, been in the wilderness of northeastern Sudan, laying a
gas pipeline, hence the bit of silence ![]() Returned a couple of hours ago (sneaked a visit to the A320 cockpit until TOD), and will be returning back there in about 3 days for another month or so, but my laptop works in the deserts too, so the Qs might just keep comin ![]() Cheers, Ramapriya PS: Don't know if they trolled me, but both the pilots today didn't seem to know much of the CFM56's internals. Possibly they didn't want to bother answering, but I'll have to look elsewhere to figure the compressor's and ignition chamber's construction... |
seem to know much of the CFM56's internals. Possibly they didn't want to bother answering, but I'll have to look elsewhere to figure the compressor's and ignition chamber's construction... too many questions.. to the wrong person or persons.. may label you a suspected terrorist.. and why would they give information like that.. to someone they don't know.. and information that is readily available in a public library? some one may come knocking on your door to check you out... BT |
![]() Ramapriya wrote: PS: Don't know if they trolled me, but both the pilots today didn't seem to know much of the CFM56's internals. Perhaps they don't know that much about the internals. Ernest Gann said he never understood why American Airlines felt it necessary that he be able to answer detailed questions about the workings of the radial engines he flew behind. He couldn't imagine climbing out on the wing to affect repairs in flight, though he said "there would be times when I fervently wished it were possible." George Patterson The desire for safety stands against every great and noble enterprise. |
10% is usually about half way to light off for a turbine engine. Starter
usually cuts out around 50% and stabilize at 60-70% core speed. Michelle Morgans wrote: "Ramapriya" wrote in message roups.com... I know that a car's engine needs to be mated to the transmission for propulsion. This I know isn't the case with an aircraft with a jet engine; if the engine is turned on without the brakes applied, the jet of air leaving the engine will hurl the craft forward. My doubt is, why does this forward motion effect not occur during push-back, when the engines are normally turned on? Is it because at low revs the engine would lack the punch to initiate the forward motion of a heavy aircraft? If not, I'd imagine the push-back becomes a bit of a tiresome affair by the time it's over... Sorry if this is infuriatingly elementary, but I need to ask somewhere ![]() Ramapriya At idle, turbo fan engines, or turbo jet engines do not make a tremendous amount of thrust. The push-back tugs are very powerful, with very low gearing. They simply push harder than the engines are pushing. Sometimes, the engines are not started until after push-back, or while the push-back is taking place. Some of the heavy metal pilots can tell you better than me, but it is my understanding that it takes well over 50% RPM to get 50% thrust, so it goes to follow that 10% RPM is way less than 10% thrust. Where have you been? Kinda' lonely around here, without your constant questions! g |
oups.com... I know that a car's engine needs to be mated to the transmission for propulsion. This I know isn't the case with an aircraft with a jet engine; if the engine is turned on without the brakes applied, the jet of air leaving the engine will hurl the craft forward. My doubt is, why does this forward motion effect not occur during push-back, when the engines are normally turned on? Is it because at low revs the engine would lack the punch to initiate the forward motion of a heavy aircraft? If not, I'd imagine the push-back becomes a bit of a tiresome affair by the time it's over... Sorry if this is infuriatingly elementary, but I need to ask somewhere ![]() Ramapriya Sometimes they don't even need a tug to get away from the gate... I've been on American Airlines MD80s that have pushed back under their own power via their reversers. Jay Beckman PP-ASEL Chandler, AZ |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 03:27 PM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
