Did the PA-28-180....
Old December 24th 04, 08:36 AM
Marty
"aluckyguess" wrote in message
How many knots would be gained with this?
Hi Lucky,
Congrats on the license!
Think of a CS propeller as an overdrive. Simply, it's purpose is to lower
the fuel consumption by taking a bigger bite of air in cruise. You basically
get the same cruise speed for less rpms.
Properly used, a CS prop also helps to maximize engine life. Improper or
misuse of a CS prop can render even a new airplane to glider status
quickly,especially turbo equipped aircraft.
There are other benefits and caveats, you will learn them if you go for a
complex endorsement.
HTH,
Marty
Old December 25th 04, 12:56 AM
aluckyguess
"Marty" wrote in message
Hi Lucky,
basically get the same cruise speed for less rpms.
HTH,
Marty
Thanks
