A Level 1 AOA clarification
Old December 26th 04, 03:56 AM
Andrew Sarangan
"Ramapriya" wrote in news:1104029481.765015.34960
@c13g2000cwb.googlegroups.com:
If my understanding is correct, an aircraft stalls beyond that AOA
which, when increased any further, produces no (further) lift. If
correct, would it be logical to infer that an aircraft's stalling AOA:
a. is dependent on its airspeed, and is independent of its weight and
weight distribution, and
No, the stall AOA is independent of both airspeed and weight.
b. varies, for a given airspeed, with the air density (altitude)
No the stall AOA does not vary with density.
The stall AOA is determined by the shape of the wing. It is independent of
weight and airspeed. However, the airspeed vs AOA relationship depends on a
variety of factors, such as weight and density. This is why stall speed is
somewhat a misleading quantity. AOA would be a better quantity.
Unfortunately there is no direct way to measure the AOA in most aircraft,
so we use the airspeed as an indirect indication of the AOA.
Old December 26th 04, 04:26 AM
Ramapriya
and
Too confusing
Getting back to basics, wings produce lift only when wind hits them,
i.e. when the aircraft starts moving. This keeps increasing until the
airspeed is adequate enough to produce a total lift that can levitate
the aircraft. Since the angle of the wings can't be varied, ignoring
flaps momentarily, I can't see how the stall AOA can be independent of
airspeed. What then is 'stall speed' of an airplane?
If stalling AOA is reached, adding engine power before the plane goes
into a stall will prevent the stall by increasing airspeed, right?
independent of
depends on a
speed is
aircraft,
Don't know much yet about this but I'm sure I saw the AOA indicated in
an A320 cockpit recently. I thought the pitch itself indicated AOA but
when the captain showed me the actual AOA reading, it varied by a wee
from the aircraft's pitch. He had to punch some buttons into the flight
computer to get the AOA reading.
Need to read up John Denker's book and the FAA material a lotttt more,
I guess :\
Ramapriya
Old December 26th 04, 05:17 AM
G.R. Patterson III
and
Too confusing
I'll try to simplify it a bit. An angle of attack is the angle at which the wing
"attacks" the air. If the air is relatively stable and you raise the nose, you
have just increased the angle of attack. Lower the nose, the angle decreases.
Ok so far?
Now. The stall angle of attack is the angle at which the airflow over the wing
won't follow the curve of the wing anymore. The wing is tilted up too steeply
relative to the airflow. If I undrestand him correctly, Andrew is stating that
the angle of attack at which this occurs is the same regardless of airspeed. I
believe he is incorrect in this - definitely my aircraft will stall at a much
lower angle of attack at 50 mph than at 60 mph, and I've never been brave enough
to get the nose high enough to stall it at higher airspeeds.
Now, there *is* a misconception that stall airspeeds are constant, and this is
not true. The way the truth is usually phrased is "an airplane can stall at any
speed." You can exceed the stall angle of attack while flying perfectly level at
a pretty fair speed if you fly into a wind that is blowing up a steep slope.
There are also "high-speed" stalls caused by attempting to maneuver too rapidly
at high speed.
The true airspeed at which a stall occurs also increases with density altitude.
This is not usually a factor for light aircraft, since the indicated airspeed
for a given true airspeed decreases at the same rate. In other words, if your
plane has a pitot tube and stalls at 60 knots indicated, it will stall in that
configuration at that speed at any altitude it can reach. If the aircraft is
equipped with an indicator that reports true airspeed, however, stall speed is
not constant.
I do not know whether or not the stall angle of attack changes with weight, but
the stall airspeed in any configuration increases as weight increases. Paul's
points on the effects of loading and the downforce produced by the tail surfaces
are also good.
George Patterson
The desire for safety stands against every great and noble enterprise.
Old December 26th 04, 06:48 AM
Peter Duniho
"G.R. Patterson III" wrote in message
the wing
you
decreases.
To elaborate a bit: Ramapriya's assertion that "the angle of the wings can't
be varied" is incorrect. The angle of the wings can be and is varied, by
using the elevator control to adjust the pitch attitude of the aircraft, and
thus of the wings.
This is what George means by "raise the nose".
[...] If I undrestand him correctly, Andrew is stating that
airspeed. I
much
You understand Andrew correctly, but not stalling.
Since you mention stalling at two different airspeeds, let's look at those
as examples. Let's assume that at the lower airspeed, you are stall in
unaccelerated flight. There are two ways to stall the airplane at a higher
airspeed then: one is to pull hard on the yoke to increase loading and pitch
attitude to stall before the airplane slows further; the other is to have
the flaps out at the slower airspeed, but not the higher.
In the first case, the pitch attitude appears higher, but the angle of
attack is the same. The airplane, because of the higher pitch angle, is
accelerating upward, which changes the direction of the relative wind
somewhat downward, making a given angle of attack occur at a higher pitch
angle.
In the second case, the pitch attitude appears higher, but the angle of
attack is the same (sound familiar? ). When the flaps are extended, the
effective chord of the wing changes, essentially pitching the wing upward
and increasing angle of attack. This increases the angle of incidence of
the wing (the angle between the wing chord and the fuselage), causing a
given angle of attack to occur at a lower pitch angle, compared to a
no-flaps stall (at a higher airspeed).
The flaps might also change the stalling angle of attack subtly, but a) most
of the perceived change in angle of attack comes from the change in
effective angle of incidence, and b) the change in AOA in that case is due
to the change in shape of the wing, not the change in airspeed.
this is
at any
speed."
You forgot the other half of that: an airplane can stall at any attitude.
Pilots often mistake pitch angle relative to the ground for angle of attack.
In level, 1-G flight this is the case. But you can exceed the critical
angle of attack with the nose pointed down (pulling out from a high-speed
dive for example), and you can have the nose pointed quite high (during a
climb in a high performance airplane, especially at lower weights), without
exceeding the critical angle of attack.
weight, but
Weight does not affect the stalling angle of attack.
Pete
Old December 26th 04, 09:02 AM
Ramapriya
wings can't
varied, by
aircraft, and
thus of the wings.
My bad. What I intended saying was that the wings on their own can't be
tilted about, barring use of flaps; they're after all rigid structures.
Cheers,
Ramapriya
Old December 26th 04, 08:05 PM
Peter Duniho
"Ramapriya" wrote in message
Even without the use of flaps, you can change the angle of the wings.
That's what the elevator control does.
Old December 26th 04, 07:35 PM
G.R. Patterson III
Well, yes I do, but not that late at night or with that much "Christmas cheer",
obviously.
Rama, in my post, I forgot that at a higher airspeed, the plane is likely to be
climbing, therefore the relative wind will be coming from above. You will reach
the same angle of attack at a steeper pitch angle at higher airspeeds.
George Patterson
Old December 27th 04, 02:04 PM
Hilton
to be
reach
What?
Hilton
Old December 27th 04, 06:40 PM
Frankster
You will reach the same angle of attack at a steeper
What?
Hilton
He's saying that, by definition, the AOA is the wing's angle to the
*relative* airflow. Pitch is relative only to the ground, and really has no
bearing on this entire discussion.
-Frank
Old December 27th 04, 05:51 PM
Greg Esres
Andrew is stating that the angle of attack at which this occurs is
the same regardless of airspeed. I believe he is incorrect in this
Andrew is 100% correct on this.
my aircraft will stall at a much lower angle of attack at 50 mph
That sentence doesn't make any sense at all. You may be confusing
pitch angle with angle of attack.
The only means you have of determining your AOA is your airspeed
indicator. At 50 mph, you are at a higher AOA than at 60 mph.
You will reach the same angle of attack at a steeper pitch angle at
higher airspeeds.
Same AOA = Same airspeed.
PIREP--CO Experts low level carbon monoxide detector Jay Honeck Piloting 10 December 3rd 04 11:21 AM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Altimeter setting != Sea Level Pressure - Why? JT Wright Piloting 5 April 5th 04 01:04 AM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 03:58 PM
flight level in Flight simulator Robert Piloting 3 August 20th 03 07:37 PM
