![]() "Ramapriya" wrote in message ups.com... Depending on what kind of plane you are flying, you may get good use out of your shoulder harness if you add power just before or during a stall. While you probably could delay the stall by adding power, it will eventually happen if you do not lower your attitude. In most cases, that is. Don't know much yet about this but I'm sure I saw the AOA indicated in an A320 cockpit recently. I thought the pitch itself indicated AOA but when the captain showed me the actual AOA reading, it varied by a wee from the aircraft's pitch. He had to punch some buttons into the flight computer to get the AOA reading. That is because the aoa depends on the relative wind. The relative really does not have much to do with where the ground is, or what your attitude is. Need to read up John Denker's book and the FAA material a lotttt more, I guess :\ Ramapriya |
ups.com... Getting back to basics, wings produce lift only when wind hits them, i.e. when the aircraft starts moving. This keeps increasing until the airspeed is adequate enough to produce a total lift that can levitate the aircraft. Since the angle of the wings can't be varied, See my reply to George. The angle of the wings CAN be varied, and doing so is essential to the art of flying. ignoring flaps momentarily, I can't see how the stall AOA can be independent of airspeed. What then is 'stall speed' of an airplane? The stall speed of an airplane is the airspeed at which the airplane will stall, assuming straight and level unaccelerated flight. Any published stall speed is actually specific to a certain weight (most popular stall speeds to know are for maximum weight), and for a specific configuration (for example, gear and flap extension both can change stall speed...especially flaps). If stalling AOA is reached, adding engine power before the plane goes into a stall will prevent the stall by increasing airspeed, right? Sort of. By the time you are down to stall speed, what additional engine power actually does is to allow you to fly at *lower* airspeeds. However, yes...commonly when one is near stalling and doesn't want to be, increasing engine power is one part of the recovery. If not combined with a reduction in pitch attitude, all that more power will do (assuming everything else is held constant) is to cause the airplane to climb. Pete |
Peter Duniho wrote:
"Ramapriya" wrote in message If stalling AOA is reached, adding engine power before the plane goes into a stall will prevent the stall by increasing airspeed, right? By reducing the AOA actually, which happens as a consequence of increasing airspeed. But see below also. Sort of. By the time you are down to stall speed, what additional engine power actually does is to allow you to fly at *lower* airspeeds. However, And it is interesting how that actually happens. The vertical component of thrust takes a bit of the load off the wings which helps reduce the AOA and keep it under the limit of the stall. Part of the weight is in fact hanging by the propeller, like a helicopter. CV |
"CV" wrote in message
... By reducing the AOA actually, which happens as a consequence of increasing airspeed. But see below also. No. Increased airspeed happens as a result of reduced angle of attack, not the other way around. Airspeed has no direct effect on AOA, though it does have indirect effects (since changes in airspeed affect what AOA you need for a given performance goal, whether that's turning, climbing, descending, or whatever). And it is interesting how that actually happens. The vertical component of thrust takes a bit of the load off the wings which helps reduce the AOA and keep it under the limit of the stall. Part of the weight is in fact hanging by the propeller, like a helicopter. Thrust does contribute, yes. But the primary reason for requiring additional power is that, while the wing is capable of generating the necessary thrust at a lower airspeed, higher angle of attack (all the way up to the stalling AOA of course), the higher angle of attack results in higher drag, requiring higher thrust. Pete |
Peter Duniho wrote:
"CV" wrote in message ... By reducing the AOA actually, which happens as a consequence of increasing airspeed. But see below also. No. Increased airspeed happens as a result of reduced angle of attack, not the other way around. Be that as it may, flying faster allows us to use a smaller AOA, which is what prevents the stall. We can stall at any speed, and at any attitude, but it always happens at the same (or very close to the same) AOA. CV |
On Sun, 26 Dec 2004 at 21:58:05 in message
, Peter Duniho wrote: Thrust does contribute, yes. But the primary reason for requiring additional power is that, while the wing is capable of generating the necessary thrust at a lower airspeed, higher angle of attack (all the way up to the stalling AOA of course), the higher angle of attack results in higher drag, requiring higher thrust. I think Peter that an aircraft will climb if trimmed to the same angle of attack that it was using in level flight. It does this as long as the lift is slightly less and the speed drops to produce _less_ drag and lift, leaving more engine power and thrust to climb. When climbing extra work must be done against gravity. That extra work can come from increasing power or from reducing speed and therefore drag. Nitpicking point: wings do not create thrust! :-) You meant lift of course. -- David CL Francis |
"David CL Francis" wrote in message
... I think Peter that an aircraft will climb if trimmed to the same angle of attack that it was using in level flight. Well, ignoring for a moment that I never meant to suggest anything about what happens if you simply increase power without changing anything else when just above stall speed... (my comments were simply about what additional power *allows*...not what it *causes*) You can't make that generalization. Changes in power affect elevator authority (affecting trim), as well as necessary rudder input (changing drag). It is entirely possible that when just above stall speed, an increase in power will result in an increase in angle of attack, an increase in drag, or both. What you can say is that if the pilot maintains the same angle of attack, but increases power, then the airplane will climb (I don't believe that added drag from rudder will ever be MORE than the added thrust, but I could be wrong about that). But that's not really what I was talking about. It does this as long as the lift is slightly less and the speed drops to produce _less_ drag and lift, leaving more engine power and thrust to climb. At an airspeed just above stall, a reduction in speed results in MORE drag. There is a reduction in parasitic drag, but there is a greater increase in induced drag, with a net increase in total drag (and that's ignoring drag caused by the rudder and any other control surfaces that require a change in position). When climbing extra work must be done against gravity. That extra work can come from increasing power or from reducing speed and therefore drag. The extra work comes ONLY from a net surplus of power. A reduction in speed is only guaranteed to produce a net increase in power available if the new airspeed is higher than Vbg. It can sometimes also produce a net increase, if the old airspeed was sufficiently higher than Vbg, and the new airspeed is close enough to Vbg, even if less than, but you need to know more about the old and new airspeeds in that case to say for sure what happens. More importantly, a reduction in speed is guaranteed to produce a net decrease of power available if the OLD airspeed is lower than Vbg (as it is when just above stall speed). Nitpicking point: wings do not create thrust! :-) You meant lift of course. Yes, of course. Thank you. Pete |
Andrew Sarangan wrote:
a. is dependent on its airspeed, and is independent of its weight and weight distribution, and No, the stall AOA is independent of both airspeed and weight. Too confusing ![]() Getting back to basics, wings produce lift only when wind hits them, i.e. when the aircraft starts moving. This keeps increasing until the airspeed is adequate enough to produce a total lift that can levitate the aircraft. Since the angle of the wings can't be varied, ignoring flaps momentarily, I can't see how the stall AOA can be independent of airspeed. What then is 'stall speed' of an airplane? If stalling AOA is reached, adding engine power before the plane goes into a stall will prevent the stall by increasing airspeed, right? b. varies, for a given airspeed, with the air density (altitude) No the stall AOA does not vary with density. The stall AOA is determined by the shape of the wing. It is independent of weight and airspeed. However, the airspeed vs AOA relationship depends on a variety of factors, such as weight and density. This is why stall speed is somewhat a misleading quantity. AOA would be a better quantity. Unfortunately there is no direct way to measure the AOA in most aircraft, so we use the airspeed as an indirect indication of the AOA. Don't know much yet about this but I'm sure I saw the AOA indicated in an A320 cockpit recently. I thought the pitch itself indicated AOA but when the captain showed me the actual AOA reading, it varied by a wee from the aircraft's pitch. He had to punch some buttons into the flight computer to get the AOA reading. Need to read up John Denker's book and the FAA material a lotttt more, I guess :\ Ramapriya |
ups.com: Andrew Sarangan wrote: a. is dependent on its airspeed, and is independent of its weight and weight distribution, and No, the stall AOA is independent of both airspeed and weight. Too confusing ![]() Getting back to basics, wings produce lift only when wind hits them, i.e. when the aircraft starts moving. This keeps increasing until the airspeed is adequate enough to produce a total lift that can levitate the aircraft. Since the angle of the wings can't be varied, ignoring flaps momentarily, I can't see how the stall AOA can be independent of airspeed. What then is 'stall speed' of an airplane? I see where you are getting the misconceptions from. You are thinking of the takeoff and landing as the start and end of flight. Just because an aircraft is on the ground does not mean it is stalled. Instead, picture an aircraft in mid flight. Then imagine what happens if you increase the angle of attack. The airflow over the wings will start to break up. This is the start of stall.This point is only related to the angle at which the airstream strikes the wing. Think of the AOA as the difference between the angle where the aircraft is pointing and where it is going. If stalling AOA is reached, adding engine power before the plane goes into a stall will prevent the stall by increasing airspeed, right? b. varies, for a given airspeed, with the air density (altitude) No the stall AOA does not vary with density. The stall AOA is determined by the shape of the wing. It is independent of weight and airspeed. However, the airspeed vs AOA relationship depends on a variety of factors, such as weight and density. This is why stall speed is somewhat a misleading quantity. AOA would be a better quantity. Unfortunately there is no direct way to measure the AOA in most aircraft, so we use the airspeed as an indirect indication of the AOA. Don't know much yet about this but I'm sure I saw the AOA indicated in an A320 cockpit recently. I thought the pitch itself indicated AOA but when the captain showed me the actual AOA reading, it varied by a wee from the aircraft's pitch. He had to punch some buttons into the flight computer to get the AOA reading. True, some of the larger aircraft and military jets have an AOA indicator. Most small aircraft do not have an AOA indicator. There is a good reason for this. In a large aircraft, the weight can vary substantially over its flight envelope. This will result in a large variation in stall speed. In a small aircraft, the stall speed variation is rather small, and a single stall speed can be used safely. Need to read up John Denker's book and the FAA material a lotttt more, I guess :\ No, you need to take a couple of flying lessons. |
True, some of the larger aircraft and military jets have an AOA indicator. Most small aircraft do not have an AOA indicator. There is a good reason for this. In a large aircraft, the weight can vary substantially over its flight envelope. This will result in a large variation in stall speed. In a small aircraft, the stall speed variation is rather small, and a single stall speed can be used safely. IMHO, there is no good reason for not having an AOA indicator on GA aircraft. Stall/spin is a leading cause of death among GA pilots and passengers. Best glide (potential emergency situation) is determined by AOA. Put an AOA sensor on GA planes with a hand that smacks the pilot on the head when the AOA approaches the critical AOA and a lot fewer people will die while having fun on the weekends. Hilton |
PIREP--CO Experts low level carbon monoxide detector | Jay Honeck | Piloting | 10 | December 3rd 04 11:21 AM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
Altimeter setting != Sea Level Pressure - Why? | JT Wright | Piloting | 5 | April 5th 04 01:04 AM |
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. | Larry Dighera | Piloting | 0 | February 22nd 04 03:58 PM |
flight level in Flight simulator | Robert | Piloting | 3 | August 20th 03 07:37 PM |
