![]() "Roger" wrote I didn't think they could sell them without them. (caps) Tanks have had to have that provision for years. OTOH there are a lot of lost caps floating around... some where. I *think* tanks with a guard around the valve, (so a blow sideways can not knock off the valve) are still legal. I have an old acetylene tank like that. If the Acetylene tank were laying down I think I'd have a problem with all the acetone coming out the torch tip. Correct. Acetylene is actually dissolved in acetone, so as you use the gas and the pressure gets lower, the acetylene "evaporates" or "comes out of solution" to come out the tip as a gas. If the tank were on its side, you would get acetone coming out of the tip. There is also another difference in the tanks, between Oxy and Acety. The Oxy tank is a big open container on the inside. The Acety. is like a metal honeycomb, or metal sponge, with the acetylene and acetone in the little cells. I think it has something to do with providing maximum surface area of the liquid, allowing the acetylene to come out of solution at rapid flow rates. -- Jim in NC |
Filling oxygen tanks | Bruce McFadden | Owning | 49 | December 28th 04 11:41 PM |
What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 07:35 PM |
F-104 in Viet Nam Question | Don Harstad | Military Aviation | 2 | August 28th 04 08:40 AM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
