![]() Morgans wrote: At cruise RPM? Sounds like you may have 1 or 2 of the three diodes burnt out in your alternator. Another possibility is that your voltmeter is off. Try checking it with a digital voltmeter, and comparing the two. Any RPM between 800 and 2700 gives the same voltage, no change. I normally read the voltage in 4 ways 1) My EDM shows it on the screen 2) My regulator flashes a voltage light on my panel when low 3) My voice annunicator says, "Check bus voltage" and 4) My A&P has been putting his probe all over the place Since I can reproduce this at idle on the ground its easy for the A&P to hook up under the panel. I should also note that... 1) Have a new battery, new master switch, and new regulator 2) I took my regulator and alternator to an aviation electrical overhaul shop. They bench tested the combo at 14v up to 100amp draw. They didn't find any diode issues, but I'm willing to believe they could be wrong. -Robert, M20F '76 |
Normal voltage drop | Robert M. Gary | Owning | 19 | January 3rd 05 04:12 AM |
C182 - Intermittent Alternator | WinstonCup | Owning | 9 | November 12th 04 12:22 AM |
no RPM drop on mag check | Dave Butler | Owning | 19 | November 2nd 04 02:55 AM |
Cessna 210 charging problem | John Clonts | Owning | 9 | July 14th 04 03:08 PM |
Anyone have experience with InterAv alternator | flyer | Home Built | 6 | October 19th 03 03:24 AM |
