Don Hammer wrote:
On 1 Jan 2005 15:17:49 -0800, "george" wrotD: Also, since TCAS has been mandated, there has been only one mid-air with equipped aircraft and it was because one crew ignored the warning. (UPS and Aeroflot in Switzerland) ????? You mean the TCAS only gives a warning, with the pilots having a say on whether or not to take action?? I was under the impression that the TCAS sytems talk to each other and take automatic action to avoid a collision!! To leave it to the pilots doesn't appear to be too much of an advantage, with a relative speed of two planes being about 1000 mph towards each other. Also, given the small reaction time, there's also a chance, howsoever small, that the pilots could both take action that'll precipitate a collision instead of avoiding one; both diving, for example. If it isn't automatic, I think the TCAS should be. For sure. Ramapriya |
EBME, eye ball measuring equipment is the most important instrument you have
in the cockpit. ALL THE OTHER AIDS ARE ONLY AIDS! Hope this helps, Peter |
![]() "Ramapriya" wrote in message oups.com... Don Hammer wrote: On 1 Jan 2005 15:17:49 -0800, "george" wrotD: Also, since TCAS has been mandated, there has been only one mid-air with equipped aircraft and it was because one crew ignored the warning. (UPS and Aeroflot in Switzerland) ????? You mean the TCAS only gives a warning, with the pilots having a say on whether or not to take action?? I was under the impression that the TCAS sytems talk to each other and take automatic action to avoid a collision!! To leave it to the pilots doesn't appear to be too much of an advantage, with a relative speed of two planes being about 1000 mph towards each other. Also, given the small reaction time, there's also a chance, howsoever small, that the pilots could both take action that'll precipitate a collision instead of avoiding one; both diving, for example. If it isn't automatic, I think the TCAS should be. For sure. Ramapriya TCAS alerts and instructions are what the pilot is supposed to follow. If ATC and the TCAS conflict then the pilot is required to follow TCAS. In the case over Germany the Russian obeyed ATC when they should have followed the TCAS. The DHL plane obeyed TCAS but still ended up wrecked because the Russian plane had not taken the action it was supposed to follow. As with all accidents measures taken earlier could have eliminated the need for conflict resolution. There was only one controller on duty that night covering a couple of sectors and he missed the problem as it was building up. when he tried to raise the Russian plane he had difficulty and so it all went on. In the end the controller was murdered by, its claimed, avenging parents of the 86 kids killed on the Russian plane. Every regulation brought in is written in someone's blood. |
Chris wrote:
TCAS alerts and instructions are what the pilot is supposed to follow. If ATC and the TCAS conflict then the pilot is required to follow TCAS. Of interest, here was the Russian view of the priorities at the time: http://www.aeronautics.ru/news/news002/news053.htm I believe they have since changed their instructions to encourage the pilots to follow TCAS recommendations. |
In article .com,
"Ramapriya" wrote: To leave it to the pilots doesn't appear to be too much of an advantage, with a relative speed of two planes being about 1000 mph towards each other. Also, given the small reaction time, there's also a chance, howsoever small, that the pilots could both take action that'll precipitate a collision instead of avoiding one; both diving, for example. 1) Reaction times are less of an issue with TCAS because normally the system will advise the crew of traffic (called a traffic advisory or TA) when the conflicting aircraft is (iirc) 40 seconds out. This allows the crew to begin scanning for the potential conflict. 2) If the two aircraft involved in a potential conflict are both TCAS II equipped, the systems will coordinate. That is, generally the higher aircraft will get a "Resolution Advisory" or RA to climb (or possibly not descend) while the lower aircraft will get a descent (or possibly not climb). If it isn't automatic, I think the TCAS should be. For sure. you have far more faith in automation than I. btw - since TCAS can only see transponder-equipped aircraft, it wouldn't be real smart to make the system automatic beause you wouldn't want the system to fly the aircraft into conflict with a non-transponder aircraft. -- Bob Noel looking for a sig the lawyers will like |
Bob Noel wrote:
-- Bob Noel looking for a sig the lawyers will like ok, how about "A good lawyer knows the law, a great lawyer knows the judge" ![]() |
Bob Noel wrote:
1) Reaction times are less of an issue with TCAS because normally the system will advise the crew of traffic (called a traffic advisory or TA) when the conflicting aircraft is (iirc) 40 seconds out. This allows the crew to begin scanning for the potential conflict. You know I'm not an aviator, but 40 secs don't appear that much. A few secs to initially notice a warning and a few more till it properly registers would take away much of the 40 secs. Moreover, the pilots could easily be doing other things at the time - a loo break, chatting up passengers while on autopilot, munching a snack, even flirting with a hostess (hope I don't get flamed for suggesting that ![]() If it isn't automatic, I think the TCAS should be. For sure. you have far more faith in automation than I. and why is it that you don't have faith in automation, Bob? Not having to use brains, and doing something by rote instead, isn't necessarily a disadvantage always. The chances of a well-programmed software consistently doing a collision avoidance routine correctly are better than two pilots doing so, I'd imagine. Ramapriya |
In article . com,
"Ramapriya" wrote: If it isn't automatic, I think the TCAS should be. For sure. you have far more faith in automation than I. and why is it that you don't have faith in automation, Bob? because I've seen how avionics software systems are developed because I've seen the state-of-the-art wrt safety-critical software. Not having to use brains, and doing something by rote instead, isn't necessarily a disadvantage always. The chances of a well-programmed software consistently doing a collision avoidance routine correctly are better than two pilots doing so, I'd imagine. 1) the chances of actually having that "well-programmed" software is pretty 2) I suggest you check out the accuracy of the TCAS II system wrt azimuth for conflicting traffic. I'm just a software guy, but my hardware guys tell me that the 4 element (4 pole?) antenna used doesn't give an azimuth accuracy of even +/- 15 degrees. -- Bob Noel looking for a sig the lawyers will like |
You know I'm not an aviator, but 40 secs don't appear that much. A few secs to initially notice a warning and a few more till it properly registers would take away much of the 40 secs. For a crew that is trained to respond to a TCAS alert by instinct, 40 seconds is plenty. Moreover, the pilots could easily be doing other things at the time - a loo break, chatting up passengers while on autopilot, munching a snack, even flirting with a hostess (hope I don't get flamed for suggesting that ![]() With a professional crew, only one pilot is chatting up the hosties. The other is flying. A professional crew always has one of the pilots placing his/her attention on the plane, even with the auto-pilot on. and why is it that you don't have faith in automation, Bob? Not having to use brains, and doing something by rote instead, isn't necessarily a disadvantage always. The chances of a well-programmed software consistently doing a collision avoidance routine correctly are better than two pilots doing so, I'd imagine. Bob understands the limitation of the equipment. It is great stuff. TCAS is a huge inprovement in safety. However, it isn't infallible. I was on the jumpseat last week when a fellow crew received a TCAS warning even though a real threat did not exist. Well-trained pilots who are supplied with good information will always be the best safety equipment. For example- the A-320 you have experienced was designed so that idiots can fly it. The idiots still manage to crash the A-320. D. |
Ramapriya wrote:
Don Hammer wrote: On 1 Jan 2005 15:17:49 -0800, "george" wrotD: Also, since TCAS has been mandated, there has been only one mid-air with equipped aircraft and it was because one crew ignored the warning. (UPS and Aeroflot in Switzerland) ????? You mean the TCAS only gives a warning, with the pilots having a say on whether or not to take action?? I was under the impression that the TCAS sytems talk to each other and take automatic action to avoid a collision!! To leave it to the pilots doesn't appear to be too much of an advantage, with a relative speed of two planes being about 1000 mph towards each other. Also, given the small reaction time, there's also a chance, howsoever small, that the pilots could both take action that'll precipitate a collision instead of avoiding one; both diving, for example. If it isn't automatic, I think the TCAS should be. For sure. 20+ years ago I knew one of the early developers of TCAS. She told me about some of the attempts at conflict resolution. For example, they started off with a rule that said if two planes were heading directly at each other, "pass with the other plane on the right". Fortunately, they did simulations: the result is the colliding planes form a decreasing-radius spiral about each other, always with the other plane on the right. |
Anti collision lights mods for Arrow 1968?? | Frode Berg | Piloting | 3 | May 20th 04 05:42 AM |
Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 05:16 AM |
New anti collision system for aircrafts, helicopters and gliders | Thierry | Owning | 10 | February 14th 04 08:36 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
"China blamed in '01 air collision" | Mike Yared | Military Aviation | 2 | September 14th 03 06:08 PM |
