Bob Noel wrote:
1) Reaction times are less of an issue with TCAS because normally the system will advise the crew of traffic (called a traffic advisory or TA) when the conflicting aircraft is (iirc) 40 seconds out. This allows the crew to begin scanning for the potential conflict. You know I'm not an aviator, but 40 secs don't appear that much. A few secs to initially notice a warning and a few more till it properly registers would take away much of the 40 secs. Moreover, the pilots could easily be doing other things at the time - a loo break, chatting up passengers while on autopilot, munching a snack, even flirting with a hostess (hope I don't get flamed for suggesting that ![]() If it isn't automatic, I think the TCAS should be. For sure. you have far more faith in automation than I. and why is it that you don't have faith in automation, Bob? Not having to use brains, and doing something by rote instead, isn't necessarily a disadvantage always. The chances of a well-programmed software consistently doing a collision avoidance routine correctly are better than two pilots doing so, I'd imagine. Ramapriya |
In article . com,
"Ramapriya" wrote: If it isn't automatic, I think the TCAS should be. For sure. you have far more faith in automation than I. and why is it that you don't have faith in automation, Bob? because I've seen how avionics software systems are developed because I've seen the state-of-the-art wrt safety-critical software. Not having to use brains, and doing something by rote instead, isn't necessarily a disadvantage always. The chances of a well-programmed software consistently doing a collision avoidance routine correctly are better than two pilots doing so, I'd imagine. 1) the chances of actually having that "well-programmed" software is pretty 2) I suggest you check out the accuracy of the TCAS II system wrt azimuth for conflicting traffic. I'm just a software guy, but my hardware guys tell me that the 4 element (4 pole?) antenna used doesn't give an azimuth accuracy of even +/- 15 degrees. -- Bob Noel looking for a sig the lawyers will like |
"Ramapriya" wrote in message
You know I'm not an aviator, but 40 secs don't appear that much. A few secs to initially notice a warning and a few more till it properly registers would take away much of the 40 secs. For a crew that is trained to respond to a TCAS alert by instinct, 40 seconds is plenty. Moreover, the pilots could easily be doing other things at the time - a loo break, chatting up passengers while on autopilot, munching a snack, even flirting with a hostess (hope I don't get flamed for suggesting that ![]() With a professional crew, only one pilot is chatting up the hosties. The other is flying. A professional crew always has one of the pilots placing his/her attention on the plane, even with the auto-pilot on. and why is it that you don't have faith in automation, Bob? Not having to use brains, and doing something by rote instead, isn't necessarily a disadvantage always. The chances of a well-programmed software consistently doing a collision avoidance routine correctly are better than two pilots doing so, I'd imagine. Bob understands the limitation of the equipment. It is great stuff. TCAS is a huge inprovement in safety. However, it isn't infallible. I was on the jumpseat last week when a fellow crew received a TCAS warning even though a real threat did not exist. Well-trained pilots who are supplied with good information will always be the best safety equipment. For example- the A-320 you have experienced was designed so that idiots can fly it. The idiots still manage to crash the A-320. D. |
Anti collision lights mods for Arrow 1968?? | Frode Berg | Piloting | 3 | May 20th 04 05:42 AM |
Anti collision light mod for Piper Arrow 1968 model? | Frode Berg | Owning | 4 | May 20th 04 05:16 AM |
New anti collision system for aircrafts, helicopters and gliders | Thierry | Owning | 10 | February 14th 04 08:36 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
"China blamed in '01 air collision" | Mike Yared | Military Aviation | 2 | September 14th 03 06:08 PM |
