Morgans wrote:
Google for that discussion, but in short, the rudder was used rapidly going from full deflection, to other side full deflection. The plane was not designed for that, and it failed. Part of the fault seems to lie with the airline, for not properly training its pilots. -- Jim in NC No Jim, I actually know that report, and the statements of both the airline and Airbus too. The surprise is in knowing that such action, which I think is natural, isn't automatically built into in the design of an aircraft. Why do you think that's so? Aren't such boat-turns normal? Should be, isn't it? Ramapriya |
![]() "Ramapriya" wrote: No Jim, I actually know that report, and the statements of both the airline and Airbus too. The surprise is in knowing that such action, which I think is natural, Rapid, opposite deflections of the rudder are not "natural," particularly in a jet transport aircraft. isn't automatically built into in the design of an aircraft. Why do you think that's so? Because designers cannot allow for every conceivable misuse of the equipment. Aren't such boat-turns normal? Not in that kind of airplane--besides, he wasn't just making a rudder turn, he was wagging the rudder back and forth. Should be, isn't it? Not necessarily. Airplanes are designed for performance that meets a particular mission. Airliners are not the same as aerobatic aircraft, for instance. -- Dan C172RG at BFM |
"Ramapriya" wrote in message
oups.com... No Jim, I actually know that report, and the statements of both the airline and Airbus too. The surprise is in knowing that such action, which I think is natural, isn't automatically built into in the design of an aircraft. Why do you think that's so? Aren't such boat-turns normal? Should be, isn't it? Ramapriya Turns in aircraft are most often intended to be what is called "coordinated." That is the ailerons and rudder are used in conjunction so that there are *no* purely horizontal forces felt by the passengers. In airline and corporate flying this is sometimes called "not making the ice cubes clink." You try to maneuver the aircraft so that the passengers, and their drinks, are not disturbed. Making these boat turns would be like filling a station-wagon automobile with children, accelerating to highway speeds, and then making an abrupt turn of the steering wheel. The children wuld go sliding all over the car's cabin. -- Scott |
tscottme wrote:
Making these boat turns would be like filling a station-wagon automobile with children, accelerating to highway speeds, and then making an abrupt turn of the steering wheel. The children wuld go sliding all over the car's cabin. Scott, Not having been in an aircraft boat-turn before, I find your example a wee addling. The kids would get hurled across the seats because the station wagon is trying to turn horizontally about its axis while being restricted in its lateral movement by the tires that are grounded. In an aircraft, there's just thin air outside, so I'd presume it'll mildly keep sliding sidewards too (in the opposite direction) while turning about its axis. It might just feel like in a briskish whirligig. Or does it? ![]() Ramapriya ayirpamar@gmail |
![]() Ramapriya wrote: In an aircraft, there's just thin air outside, so I'd presume it'll mildly keep sliding sidewards too (in the opposite direction) while turning about its axis. It might just feel like in a briskish whirligig. I've never been in a briskish whirligig, so I don't know, but, when you make a rudder turn, momentum attempts to have the contents continue in a straight line. In some areas of a large aircraft, unsecured cargo would slide sideways in such a turn. In a coordinated turn, the forces of momentum and gravity balance out. As far as passengers are concerned, uncoordinated maneuvers tend to make them nauseous. This effect is stronger the further away from the center of the wing they sit. George Patterson The desire for safety stands against every great and noble enterprise. |
oups.com... Not having been in an aircraft boat-turn before, I find your example a wee addling. The kids would get hurled across the seats because the station wagon is trying to turn horizontally about its axis while being restricted in its lateral movement by the tires that are grounded. In an aircraft, there's just thin air outside, so I'd presume it'll mildly keep sliding sidewards too (in the opposite direction) while turning about its axis. It's a little of both. It won't be as bad as the aforementioned station wagon, because the rudder isn't capable of producing as much of a turn. In fact, this is why it's so important to use aileron to bank the plane too for a turn. But a turn does still happen to a lesser degree, and the passengers would still feel the apparent force pushing them to the outside of the turn. Pete |
"Peter Duniho" wrote: "Ramapriya" wrote in message oups.com... Not having been in an aircraft boat-turn before, I find your example a wee addling. The kids would get hurled across the seats because the station wagon is trying to turn horizontally about its axis while being restricted in its lateral movement by the tires that are grounded. In an aircraft, there's just thin air outside, so I'd presume it'll mildly keep sliding sidewards too (in the opposite direction) while turning about its axis. It's a little of both. It won't be as bad as the aforementioned station wagon, because the rudder isn't capable of producing as much of a turn. In fact, this is why it's so important to use aileron to bank the plane too for a turn. But a turn does still happen to a lesser degree, and the passengers would still feel the apparent force pushing them to the outside of the turn. There's another thing that happens when you stomp on the rudder: while the plane is yawing about its vertical axis, one wing is moving faster than the other through the air and therefore generates more lift, causing the plane to bank even without any aileron input. But the plane yaws first and banks afterwards, so the effect is that the wing makes this sort of circular stirring motion. It can be quite disconcerting if you're not used to it. BTW, Ramapriya, where do you live? Pilots are a generous lot, and you can probably find someone to take you up so you can experience all this firsthand. rg |
Ron Garret wrote:
BTW, Ramapriya, where do you live? Pilots are a generous lot, and you can probably find someone to take you up so you can experience all this firsthand. I normally live and work in Dubai, United Arab Emirates. For about a month or so more, I'll be in Khartoum (Sudan). Just yesterday, I've lined up someone who knows the owner and pilot of a YAK-40. I'll go check out his patience one of these days ![]() I also have my eyes on a long-disused YAK-40 lying within the airport premises. I hear the owner might pay if someone takes it, so... ![]() Ramapriya |
On Thu, 6 Jan 2005 at 09:35:46 in message
, Peter Duniho wrote: It's a little of both. It won't be as bad as the aforementioned station wagon, because the rudder isn't capable of producing as much of a turn. In fact, this is why it's so important to use aileron to bank the plane too for a turn. But a turn does still happen to a lesser degree, and the passengers would still feel the apparent force pushing them to the outside of the turn. I have no special theory abut the sad crash - I just don't know enough about it - but the comments about why the loading cases are 'not as high as they should be' caused me to start writing. I don't know how much steady yaw 'g' can be generated by an airliner. I do know that there are smaller high powered aircraft that can fly 'knife edge' and must therefore be capable of generating a steady one 'g' yaw 'acceleration'. I have doubts as to whether a station wagon can generate much more than one 'g' in a turn. But my point is this. Higher loads and angles of yaw can be generated by control inputs that are in phase with the natural yaw frequency. A single application of full rudder will generate a deflection in yaw which may overshoot the final steady state yaw deflection which will then be damped out. However if control inputs are added so as to increase the yaw rate as the aircraft oscillates from one side to the other then it is theoretically possible to generate very large loads indeed. The maximum will be generated dependent on the amount of yaw damping present and the energy inputs. An operating yaw damper does the opposite; it operates so as to reduce the amplitude of yaw oscillations. The same sort of thing can occur in pitch but conventional aircraft are likely to have much better damping in pitch than yaw. The classic phugoid oscillation in pitch is not often mentioned, the ones I am referring to here are the short period stability oscillations. I believe this driving up of the deflections might be described as 'pilot induced oscillations'. I have not the data to answer the questions posed by this but the possibility may be there. The fact that yaw dampers are often fitted to assist the pilot (human or auto) seems to suggest that at some parts of the flight envelope large deflections of yaw angle need to be reduced. ('Yaw dampers' may also be part of a system to produce automatic balanced turns but that is not the effect I am alluding to. Why can flutter be so destructive? Because at certain speeds the input of aerodynamic forces changes in such a way as to drive the structure to deflect beyond its limits in an oscillatory way. Divergence means that a single structural defection will increase the load on the structure so much that it bends enough to reinforce the aerodynamic force and this can lead to catastrophic failure. It is however rare in aircraft! Peter:- believe me it was only after I had written this that I realise I had entered quoting your post. Several posts before that made me want to react. I am not reacting directly because of your post. I am not following you about - honest! -- David CL Francis |
"David CL Francis" wrote in message
... [...] I am not following you about - honest! That's alright...I was just getting over my previous persecution complex. I needed something new to obsess about. ![]() |
A Q on horizontal turns | Ramapriya | Piloting | 2 | January 8th 05 05:57 PM |
Why is a standard hold right turns? | Roy Smith | Instrument Flight Rules | 51 | August 28th 04 06:09 PM |
Canyon Turns | Marc Lattoni | Piloting | 35 | March 19th 04 06:02 PM |
Missile skid turns? | Jim Doyle | Military Aviation | 9 | March 16th 04 02:52 PM |
Can F-15s making 9G turns with payload? | Paul J. Adam | Military Aviation | 114 | September 27th 03 05:47 AM |
