What model of radio? you can alway buy a nice discone antenna will add some
dustance but if you have a cheap radio nothing will help much. "northernsurferboy" wrote in message ... I got a cheap radio shack airplane scanner. It works great when I sit in the airport parking lot but 5 km out it does nothing. I live about 15 km from a small airport and 40 from Pearson Internation Airport. Is there a external antenna I can clip on to this thing to boost its receiving capabilites? |
On Thu, 6 Jan 2005 00:27:16 -0500, "northernsurferboy"
wrote in :: Is there a external antenna I can clip on to this thing to boost its receiving capabilites? It's important to have a visual path between the transmitter and receiver, so antenna height is part of the issue. Here's something you should find interesting: http://groups-beta.google.com/group/... 6e6620c29b95 Now how about answering one for me. Why did you find it necessary to cross post your inquiry to the binary newsgroups? rec.aviation.piloting alt.binaries.multimedia.aviation alt.binaries.pictures.aviation alt.aviation.student |
Can u unplug or unscrew the aerial to get a bigger/better aerial on there?
-=Plane Mad=- wrote:
Can u unplug or unscrew the aerial to get a bigger/better aerial on there? "northernsurferboy" wrote in message .. . I got a cheap radio shack airplane scanner. It works great when I sit in the airport parking lot but 5 km out it does nothing. I live about 15 km from a small airport and 40 from Pearson Internation Airport. Is there a external antenna I can clip on to this thing to boost its receiving capabilites? which scanner do you have ?? I have a Pro-26 and it works fine. I do have a mag mount antenna I use and I do monitor Pearson But only when the plane is in the air. go here for some freq's http://www.canairradio.com/ |
Just remember, VHF comm is line of site. If you can't see it, you can't
hear it (well sort of). I can't hear the tower on the airfield sometimes with the large hangars in the way. Our TX antennae are less than 50 feet above the ground, often less than 20. You should have no problem picking up aircraft, though. northernsurferboy wrote: I got a cheap radio shack airplane scanner. It works great when I sit in the airport parking lot but 5 km out it does nothing. I live about 15 km from a small airport and 40 from Pearson Internation Airport. Is there a external antenna I can clip on to this thing to boost its receiving capabilites? -- Dale G Elhardt Cypress Ca "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." http://home.comcast.net/~laxet/ http://www.jetphotos.net/showphotos.php?userid=7702 |
On Fri, 07 Jan 2005 14:20:07 -0800, the Legend of LAX
wrote: I can't hear the tower on the airfield sometimes with the large hangars in the way. I have the same problem with the Unicom at the local field, but not because of the hangars. The lads in the shack turn it down so as not to interrupt their cribbage game. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
Radio band scanner | Fritz | General Aviation | 3 | October 14th 04 07:36 PM |
Aero scanner on websat | websat | General Aviation | 0 | July 31st 04 10:44 AM |
Scanner | Greg | General Aviation | 7 | March 7th 04 06:06 PM |
Aviation radio scanner tips? | Jim Atkins | Military Aviation | 4 | February 12th 04 06:58 PM |
sounds of aviation navigation equipment as head on a scanner radio | Dan Jacobson | Instrument Flight Rules | 5 | December 4th 03 07:27 PM |
