![]() "jharper aaatttt cisco dddooottt com" "jharper aaatttt cisco dddooottt com" wrote in message news:1105391055.635118@sj-nntpcache-3... At sea level, the change in atmospheric pressure with altitude is close to 1"Hg/1000'. Logically, this would mean that the air pressure would drop to zero somewhere not much above 30000'. It doesn't, because as the density drops the variation with altitude also changes. Which brings to mind the question, how does an altimeter deal with this? As far as I know, it's just a simple aneroid barometer with a bunch of linkages and gears to turn its expansion into pointer movement. My altimeter is marked "accurate to 20000' ". Is this why? Do altimeters for higher altitudes have some kind of clever mechanism to deal with the non-linearity of pressure at higher altitudes. I asked my acro instructor (10K+ hrs, airforce instructor pilot, ex U2 pilot so should know a thing or two about high altitudes). He explained the non-linearity of pressure to me but was stumped on how this translates to the altimeter mechanism. Anyone know? The following is a WAG but that could be the reason that in the Flight Levels, above 18k feet everyone sets thier altimeter to 29.90. |
![]() "Gig Giacona" wrote in message ... "jharper aaatttt cisco dddooottt com" "jharper aaatttt cisco dddooottt com" wrote in message news:1105391055.635118@sj-nntpcache-3... Anyone know? The following is a WAG but that could be the reason that in the Flight Levels, above 18k feet everyone sets thier altimeter to 29.90. Hopefully, 29.92. |
![]() "Icebound" wrote in message ... "Gig Giacona" wrote in message ... "jharper aaatttt cisco dddooottt com" "jharper aaatttt cisco dddooottt com" wrote in message news:1105391055.635118@sj-nntpcache-3... Anyone know? The following is a WAG but that could be the reason that in the Flight Levels, above 18k feet everyone sets thier altimeter to 29.90. Hopefully, 29.92. That still wouldn't help since the pressure change for a 1000ft change in altitude at 18k would be smaller than at sea level. It would have to have some non-linear spring compensation as a function of absolute pressure. |
some non-linear spring compensation as a function of absolute pressure. It could also be a non-linear gear compensation, such as using non-circular gears. Lotsaways it =could= be done, but I don't know how it =is= done. Jose -- Money: What you need when you run out of brains. for Email, make the obvious change in the address. |
I couldn't be done easily with a spring. Springs are very linear except in
very special cases. I think it's done with leaver arms that change effective length with displacement. Rod "Sriram Narayan" wrote in message news:1105397045.6c0b9af7d0985bd99dd3e30aa7ae44ee@t eranews... "Icebound" wrote in message ... "Gig Giacona" wrote in message ... "jharper aaatttt cisco dddooottt com" "jharper aaatttt cisco dddooottt com" wrote in message news:1105391055.635118@sj-nntpcache-3... Anyone know? The following is a WAG but that could be the reason that in the Flight Levels, above 18k feet everyone sets thier altimeter to 29.90. Hopefully, 29.92. That still wouldn't help since the pressure change for a 1000ft change in altitude at 18k would be smaller than at sea level. It would have to have some non-linear spring compensation as a function of absolute pressure. |
Sriram Narayan wrote:
That still wouldn't help since the pressure change for a 1000ft change in altitude at 18k would be smaller than at sea level. It would have to have some non-linear spring compensation as a function of absolute pressure. Yes but the non-linearity is very weak. I coded up the formula for the US standard atmosphere (described below) and plotted it. See http://www.burningserver.net/rosinsk...atmosphere.jpg Perhaps the non-linearity is so weak that altimeters neglect it? I don't know. The formula for US standard atmosphere can be derived from the ideal gas approximation (p = rho*R*T) and the hydrostatic approximation (dp/dz = -rho*g). The final equation is: z = T0/gamma * (1 - (p/p0)**(R*gamma/g))) where R=287, T0 = 288K, p0 = 1013.25 mb = 29.92 in, gamma = 6.5 deg/km, g = 9.8. The formula assumes that temperature decreases linearly with altitude, an assumption which becomes invalid above the tropopause. The equation and its derivation can be found in Wallace & Hobbs, "Atmospheric Science", pg. 60-61. Jim Rosinski |
![]() "jim rosinski" wrote in message oups.com... Sriram Narayan wrote: That still wouldn't help since the pressure change for a 1000ft change in altitude at 18k would be smaller than at sea level. It would have to have some non-linear spring compensation as a function of absolute pressure. Yes but the non-linearity is very weak. I coded up the formula for the US standard atmosphere (described below) and plotted it. See http://www.burningserver.net/rosinsk...atmosphere.jpg Perhaps the non-linearity is so weak that altimeters neglect it? I don't know. The formula for US standard atmosphere can be derived from the ideal gas approximation (p = rho*R*T) and the hydrostatic approximation (dp/dz = -rho*g). The final equation is: z = T0/gamma * (1 - (p/p0)**(R*gamma/g))) where R=287, T0 = 288K, p0 = 1013.25 mb = 29.92 in, gamma = 6.5 deg/km, g = 9.8. The formula assumes that temperature decreases linearly with altitude, an assumption which becomes invalid above the tropopause. The equation and its derivation can be found in Wallace & Hobbs, "Atmospheric Science", pg. 60-61. Jim Rosinski It doesn't look that linear to me. I found a website with a similar graph and it appears that at sea level and at 10000ft the slope of the curve is at least 2x different. Your curve is quite a bit more linear (maybe 20% increase in slope at 10k). There must some sort of mechanical compensation involved otherwise altimeters would be off quite a bit even at 10k (even with your curve). Isn't it something like 75ft accuracy requirement for altimeters? http://www.atmosphere.mpg.de/enid/16h.html |
It doesn't look that linear to me. I found a website with a similar graph and it appears that at sea level and at 10000ft the slope of the curve is at least 2x different. Your curve is quite a bit more linear (maybe 20% increase in slope at 10k). There must some sort of mechanical compensation involved otherwise altimeters would be off quite a bit even at 10k (even with your curve). Isn't it something like 75ft accuracy requirement for altimeters? http://www.atmosphere.mpg.de/enid/16h.html His graph has more curvature than mine does because his covers a much greater vertical distance (11000 meters is around 36000 feet). Mine only goes to 18000 feet. But I agree that a linear assumption will result in a worst-case error of several hundred feet. Not good enough, so the nonlinearity must be built into altimeters even if the're only good to 20000 ft. Jim Rosinski |
![]() "jim rosinski" wrote in message ups.com... Sriram Narayan wrote: It doesn't look that linear to me. I found a website with a similar graph and it appears that at sea level and at 10000ft the slope of the curve is at least 2x different. Your curve is quite a bit more linear (maybe 20% increase in slope at 10k). There must some sort of mechanical compensation involved otherwise altimeters would be off quite a bit even at 10k (even with your curve). Isn't it something like 75ft accuracy requirement for altimeters? http://www.atmosphere.mpg.de/enid/16h.html His graph has more curvature than mine does because his covers a much greater vertical distance (11000 meters is around 36000 feet). Mine only goes to 18000 feet. But I agree that a linear assumption will result in a worst-case error of several hundred feet. Not good enough, so the nonlinearity must be built into altimeters even if the're only good to 20000 ft. Oops, thanks for pointing that out. Didn't check the Y-scale carefully. |
