![]() You get the strongest wingtip vortices when an aircraft is flying heavy, clean and slow. But why? Re slow: the airplane stays aloft in effect because its wings are pushing air down. If it's moving fast, the momentum of the displaced air is spread over a larger distance, so it's more diffuse. Slower means there's much more energy in the air. Not so sure about dirty v clean, but at low speeds clean isn't very effecient at generating lift. That means larger angles of attack, more air displaced, maybe a bigger vortex. |
![]() Not so sure about dirty v clean, but at low speeds clean isn't very effecient at generating lift. That means larger angles of attack, more air displaced, maybe a bigger vortex. Clean, the angle of attack of the WINGTIPS is greater for the same lift at the same speed. The vortex happens at the wingtips, not the wing as a whole. -- Wm. Donald (Don) Tabor Jr., DDS PP-ASEL Chesapeake, VA - CPK, PVG |
Dan Girellini wrote:
From http://av8n.com/how/htm/airfoils.html#sec-wake-vortices: You would think that...flaps extended would be the absolute worst, but that is not quite true. The flaps do increase the circulation-producing capability of the wing, but they do not extend over the full span. Therefore a part of the circulation is shed where the flaps end, and another part is shed at the wingtips. If you fly into the wake of another plane, two medium-strength vortices will cause you less grief than a single full-strength vortex. Therefore, you should expect that the threat from wake vortices is greatest behind an airplane that is heavy, slow, and unflapped. Yeah. Go tell Denker to fly behind a flapped 757 on an approach. http://www.aopa.org/asf/asfarticles/sp9810.html http://www.aopa.org/asf/asfarticles/sp9403.html Hilton |
