![]() nobody wrote: "Frank F. Matthews" wrote: Actually I haven't seen many small aircraft and no empty flights in the US for the past several years. The problems are a lack of revenue and not a lack of passengers. Now finding passengers wanting to fly limited routes so as to fly a 380 that may be a problem. You don't get it. There are markets where demand is high. High enough that the USA airlines, instead of getting bigger planes, put multiple flights one after the other because they philosophically refuse to fly a big plane. Trans-atlantic flights don't need much frequency becayse the window is not that big. In the evening, you can run on big flight and it won't affect passenger's schedules, especially if it means you get the prefered landing slot at LHR to allow the right connections. Southwest's "one plane fits all", has already been broken since WN has 737s of different sizes. Secondly, it is also its achile's heel. Right now, ON AVERAGE, Southwest's policy works out with costs that are lower than the legacy carriers. Not so much because the 737 is a better plane for its whole network, but simply because Southwest is better runned, better managed, and has better staff. (costs less, does more). The 737s are a better size for Southwest. They fit the model of rapid turn around and quick boarding. A significantly larger plane would blow the business model. However, if you were to clone Southwest, and then make changes to that clone so that it would sharply focus its fleet to have the most efficient aircraft for a specific route and be able to manage that fleet properly, the cloned Southwest would be able to have lower costs on many routes compared to the original Southwest, and more importantly, would be able to serve markets that the current Southwest can't serve. So, take AA for instance on its JFK-LHR route. Because it operates a large number of flights, its average crew/pax ratio is higher than airlines that operate fewer flights with bigger planes. So AA's costs have to be higher on that route. Similarly, because AA lacks 747s, it can't really serve asia well, nor the south pacific, and must rely on its Oneword partners. Consider the case of Virgin. It started off with a few aircraft that were extremely well focused on the routes it wanted to fly and it was succesful and grew from there. AA is too big and wants to apply one-plane-fits-all for its intl flights to simplify its fleet. But that means that individual flighst are not operated at best possible efficiency, especially on routes where you have someone like Virgin that does operate at best efficiency for that route. Yes, there are compelling arguments to reduce aircraft types in a fleet. But when your 777s used domestically are different from those on atlantic and different from those used in pacific, does that really give you much in terms of fleet flexibility ? The minute you change seat assignments due to aircraft change, you get the same headaches. On long hauls though, there is a compelling argument in favour of using 1 plane type on a route. Why ? So that at your remote base, any pilot currently staying there is able to take the next flight back should one crew be incapacitated etc. Having fewer plane types may simplify fleet management and maintenance. But it also means that your network does not operate at its most efficient level because you're not using the best aircraft for your routes, you're using an aircraft that is average for your average route. What happens when for each route you operate, there is a smaller airline that operates a far more efficient aircraft for that route ? Then none of your flighst are competitive, even though on paper, your fleet is well managed. |
Air Force conducts live test of MOAB | Otis Willie | Military Aviation | 0 | November 21st 03 10:45 PM |
