Recently, Larry Dighera posted:
On Wed, 26 Jan 2005 13:36:42 GMT, "Neil Gould" wrote in :: Recently, Larry Dighera posted: On Sun, 23 Jan 2005 13:24:18 GMT, "Neil Gould" wrote in :: Recently, Larry Dighera posted: On Sat, 22 Jan 2005 21:31:46 GMT, "Neil Gould" wrote in As I was taught, the point of flying safely is to always have a viable option. So, I fly tight patterns and make power-off landings as a rule. If I make it to the pattern, I can make it to a runway, engine or no. Truly? So when you're #5 in the pattern (which necessitates a looooong, extended downwind leg) you just fly the pattern at 2,000' then? Of course not, one has to use common sense, for example, fly the pattern slower rather than lower So your aircraft is slow enough to permit you to remain within gliding distance of the threshold at normal pattern altitude while four other aircraft head cross country several miles from the runway? Doubtful. Larry... be reasonable! I hadn't realized that I wasn't. It was your use of the absolute word 'always' and the phrase 'as a rule' that prompted me to question your meaning. So... you object to "always" having a viable option? No. Obviously, there will be times when one *doesn't* have a viable option. That was my point. Poorly made, I might add. Risk management is an unavoidable part of daily life, and as such shouldn't require a lot of explanation. Ergo, you were not being reasonable. Still, I agree with my instructors advice that abandoning viable options by choice shouldn't be considered "safe flying". Given your statement above, your choice should be to divert to another airport when there are several aircraft in the pattern necessitating an extended downwind leg in excess of gliding distance to the runway, right? How would *increasing* the time in which an engine failure might occur by flying to another airport be the best way to maintain viable options? If one is concerned about the status of one's engine, one should minimize their dependence on it, no? ;-) Nor should applying "rules" where doing so results in the abandonment of viable options (even FARs don't insist on such behavior). So, no, I don't think you were being reasonable, just argumentative. Could it be that I was attempting to point out, that your instance on remaining within gliding distance of the runway failed to consider the fact that it is often impossible at busy airports? Isn't that reasonable? Not really. Unless you actually believed that I was in some way implying that no XC should ever take place. Was that to be your next point (of course, "...make it to the pattern" would have made such an argument difficult)? ;-) Regards, Neil |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Night engine failure in Boston | Dan Luke | Piloting | 8 | February 13th 04 05:33 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
