On Wed, 26 Jan 2005 16:12:28 GMT, Larry Dighera
wrote: Could it be that I was attempting to point out, that your instance on remaining within gliding distance of the runway failed to consider the fact that it is often impossible at busy airports? Isn't that reasonable? Sounds reasonable to me. Do the safer thing! Where I fly, that's generally a close-in pattern and power off abeam the landing spot. If that causes problems in the pattern, then the safer thing is to fly a wider pattern at a higher speed. -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Night engine failure in Boston | Dan Luke | Piloting | 8 | February 13th 04 05:33 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
